Bearing matching with aftermarket rods??
Old Mar 5, 2004 | 04:45 PM
VTC_CiViC's Avatar
Default Bearing matching with aftermarket rods??
Ok quick question here.. as I understand, the OEM rods are stamped with the color bearing used on each rod, are the Eagle rods also stamped? And if not, how do you determine which bearing to use?
Old Mar 5, 2004 | 04:47 PM
Irishweird00's Avatar
Banned
Default Re: Bearing matching with aftermarket rods?? (VTC_CiViC)
get some ACL's... save yourself alot of time and money.
Old Mar 5, 2004 | 04:49 PM
VTC_CiViC's Avatar
Default Re: Bearing matching with aftermarket rods?? (Irishweird00)
Well even if I get ACL's, don't they come in different sizes?
Old Mar 5, 2004 | 04:50 PM
Banned
nope... standard size... but they are within spec..
check this thread out... https://honda-tech.com/zerothread?id=628073
or pm earl, and he'll give you the low down on both oem and acl bearings
Old Mar 5, 2004 | 05:06 PM
VTC_CiViC's Avatar
Wow.. nice reading
Old Mar 5, 2004 | 05:49 PM
turbo96wr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Wow.. nice reading </TD></TR></TABLE>
if your crank is good you just need standard bearings you can also look into king bearings. good price for them. also the number on the rod with the letter on the crank determines the color you must have a helm's manual to find the color. sometimes the bearings still have the color on the side also check that.
AFAccord
Aug 3, 2015 03:26 AM
KdEj1
Sep 15, 2012 07:12 PM
MotorMouth
Jan 1, 2007 10:59 AM
EGUK
Nov 27, 2006 10:32 AM
EKweezy
Oct 8, 2003 10:09 AM
