loose timing belt?!?
here's a short vid of my timing belt as i'm hitting the throttle
notice the "looseness" from left to right
is this more than usual?
i have an erratic idle problem that goes with this
idles at 2k when i first start...
then well after warm up idles from 1.1k to 1.5k constantly
could my "loose" belt have something to do with this?
have an lsvtec setup
please help??
http://www.idpresents.com/tbelt.MOV
Modified by romJones at 5:28 AM 3/6/2004
please help??
Don't think the problem lies within the timing belt. But how much freeplay does the belt have when the car is off? I believe it should be able to move on the longer side about an inch back and forth.
But as for your idle, I would check your IACV, TPS, ignition timing, maybe even too much fuel, or even a vacuum leak. These are some of the things I'd check first. Good luck.
should it play around like that?
