Can you figure out why my car isn't running right?
Old Mar 5, 2004 | 12:59 PM
NickQ's Avatar
Default Can you figure out why my car isn't running right?
*Setup in sig*
The car idles kind of weird. Up and down a few hundred RPMs
At high RPMs (between 6-8000) it cuts out. Loses power big time. Kind of feels like it either:
a) is not getting fuel
b) vtec is switching off and on
c) some sort of electrical problem
I have no idea. It runs fine for normal driving, problem is only under acceleration. And it does not happen everytime. I would say it happens 8-10 times. I have dissassembled the distributor, tested everything. Dissassembled the VTEC solenoid/assembly, cleaned, lubed, ect). Replaced plugs. Checked all wiring. And timed it. Still having the problem.
Any help on what this might be would be very much appreciated. If I can't figure it out, the next stop is the honda mechanic ($$$$$$$$).
Old Mar 6, 2004 | 10:44 PM
NickQ's Avatar
anyone?
Old Mar 7, 2004 | 12:04 AM
tegmech's Avatar
have you thought about your fuel pump/filter? good idea to check that just incase.
Old Mar 10, 2004 | 03:00 PM
NickQ's Avatar
Default Re: (tegmech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegmech &raquo;</TD></TR><TR><TD CLASS="quote">have you thought about your fuel pump/filter? good idea to check that just incase. </TD></TR></TABLE>
The pump is fairly new. Same for the filter. If I can't figure anything out, I'll check into those.
Any other ideas
Old Mar 10, 2004 | 04:47 PM
doublejz's Avatar
Default Re: (NickQ)
tps, make sure its calibrated and giving you 0.45-0.50 volts for idle and 4.45 or higher for WOT
Old Mar 11, 2004 | 11:42 AM
NickQ's Avatar
Default Re: (doublejz)
Great. I'll check that this afternoon. Thanks for the info!!
hontoyo
Apr 18, 2009 05:30 PM
jdm_vtec
13
Jun 5, 2007 03:47 PM
AZDB8
Nov 17, 2006 02:24 PM
92integraVTECgsr
Aug 30, 2005 10:39 AM
