will installing safc without changing any settings keep my car running like stock?
I have an apexi safc and i want to install it this weekend.
i have a greddy blue box for my turbo which im going to remove soon.
I just want to install it without it screwing around with the settings on my ride.
will it change anything?
thanks!
thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phthalo »</TD></TR><TR><TD CLASS="quote">you need to program in the stock settings on the safc. </TD></TR></TABLE>
Not true. When you follow the directions on the initial setup for the unit, it tells you waht to do as far as the sensor input goes. The fuel map is all at zero when you install it, so it will run off of the factory map in the ECU. so pretty much just install it, inititalize it and go. You dont need to program anything at all if you want to keep all the stock settings.
Rob
Rob
