s-afc after install symptoms
Old Mar 15, 2003 | 09:20 AM
altoid's Avatar
Default s-afc after install symptoms
i installed the S-AFC on my car. i was running very very very rich and only the throttle voltage seemed to be correct. Is this normal (for the a/f ratio) after you install the s-afc, and does anyone have a pm6 ecu diagram so i can properly install this thing. both i got, one from the apexi website and from the manual i bought, seemed to be bogus. any help's appreciated. thanks
Old Mar 15, 2003 | 01:13 PM
altoid's Avatar
Default Re: s-afc after install symptoms (altoid)
what about having the s-afc reset it's self everytime you hit the throttle?
Old Mar 15, 2003 | 11:26 PM
Urban Business
Guest
Posts: n/a
if you install a brand enw safc, it'll run your stock ecu map. makes no changes to anything. if you have a used one, initialize it 1st. make sure you set it up properly. (manual is on apex website). make sure its wired properly. its pretty self explanitory. 2 grounds, 2 powers i believe, map in map out, tps, rpm. can do the safc hack w/ o2 sensor right away if you want to as well.
Old Mar 16, 2003 | 05:28 AM
altoid's Avatar
Default Re: s-afc after install symptoms (limoZeen)
so i have what the brown, black, red, green, white, yellow, and gray wires do what about the rest? I've looked in all the documentation for what those wire are used for and can't find anything. I read that the blue is the o2, is anything else important?
Old Mar 16, 2003 | 11:41 AM
dwn-shift's Avatar
you should have two wires left i think the pink and the orange. I didnt hook those up and mine runs fine. I am not sure you need to hook up the other two, but i may be mistaken.
silly sohc
Jun 20, 2004 08:36 PM
igo4bmx
Mar 5, 2004 06:14 PM
krazyDOHC
Mar 20, 2003 06:15 PM
Greg123
Feb 11, 2003 07:01 PM
