Finally some dyno numbers...
Old Mar 5, 2004 | 11:59 AM
1BadCvC's Avatar
Default Finally some dyno numbers...
Decent numbers i suppose. I was shooting for 200...But got some dam good gains throughout the powerband.
Modified by 1BadCvC at 9:23 PM 3/5/2004
Old Mar 5, 2004 | 12:01 PM
Casey's Avatar
Default Re: Finally some dyno numbers... (1BadCvC)
how bout a list of mods and a graph?
Old Mar 5, 2004 | 12:04 PM
1BadCvC's Avatar
Default Re: Finally some dyno numbers... (Casey)
lol im tryin atm...strugglin with scanner
well its sideways, but i gave it my best.
Modified by 1BadCvC at 9:24 PM 3/5/2004
Old Mar 5, 2004 | 12:28 PM
1BadCvC's Avatar
as for mods...AEM cai, fpr, fuel rail
complete MSD, slight PnP on the head, 12.5:1 JE's with Eagle H beams
sleeves, block gaurd, skunk 2 cam gears, im sure im forgetin some things but that should give you some idea
Old Mar 5, 2004 | 01:25 PM
slammed_93_hatch's Avatar
wow id be pretty pissed considering you can reach numbers like these https://honda-tech.com/zerothread?id=762934 with out touching the bottom end.
Old Mar 5, 2004 | 01:43 PM
GOLDBERG's Avatar
what kinda fuel setup and what was used to tune?
Old Mar 5, 2004 | 02:42 PM
1BadCvC's Avatar
Default Re: Finally some dyno numbers... (GOLDBERG)
well, i got an AEM fpr, fuel rail. As far as the tuning he just played with the cam gears, distributor. However, this bottem end i bought like this, due to hydrolocking the jdm one...i discovered i had a warped block after blowing the headgasket, and i just had to purchase larger pistons, because my cylinders where cone shaped, from 5-10 thousandths. I would think that would downsize the dyno numbers i dont know
Old Mar 5, 2004 | 10:19 PM
builtprelude's Avatar
I think with bigger cams for that compression would really help also If you got some sort of engine management. I would reccomend hondata but if you have no good tuners around you just go with a vafc or if you have the money aem ems
Old Mar 6, 2004 | 04:55 AM
radzer0's Avatar
Default Re: (builtprelude)
u got a 5speed or auto?
im looking at a auto car.. it has alot more than your car does
but same thing as your car.. it needs cams.. it would make another 40hp at the motor if just it had some good cams.. and a intake manifold
Old Mar 6, 2004 | 08:35 AM
Default Re: (radzer0)
shut up please your spewing non sense and bull ****.
gutted-dx
154
May 31, 2014 02:01 PM
d16dcoe45
25
Jan 20, 2007 05:00 AM
2SlowDC
Nov 22, 2005 06:56 AM
blkonblkcrime
Jan 9, 2005 10:17 AM
PM-Performance
Aug 11, 2002 09:51 AM
