slight popping from the front end under light braking ... cant find problem
Old Mar 5, 2004 | 05:52 AM
kevin6t9's Avatar
Default slight popping from the front end under light braking ... cant find problem
i have a 98 ek hatch.... does anyone know where this popping is coming from .. i checked the steering rack and it was ok .. has anyone else had this problem
any help would be greatly appreicated
Old Mar 5, 2004 | 06:04 AM
xerox445's Avatar
Default Re: slight popping from the front end under light braking ... cant find problem (kevin6t9)
are your cv boots torn?
Old Mar 5, 2004 | 06:09 AM
mike1114's Avatar
Default Re: slight popping from the front end under light braking ... cant find problem (xerox445)
do you have coilovers? It could be the springs creaking.
possibly that shock is blown on one side?
It could be the spring is eating away the bushing at the top of the shock tower and sometimes theres a metal to metal contact, making the noise.
Check these three things out too...its either what xerox said or what I said.
Old Mar 5, 2004 | 06:14 AM
monicle's Avatar
I would check the bolt that holds the controll arm to the subframe. Mine was doing the exact same thing and it ended up being that. In my situation the nut welded inside the subframe actually broke off and worked its way off of the bolt so the sound I was hearing were the threads of the bolt on the subframe. Check it out here http://repo.jackmoves.com/album139
Old Mar 5, 2004 | 01:52 PM
kevin6t9's Avatar
thanks for the help i will check those out..
Bizarre
Suspension & Brakes
Jul 19, 2008 08:08 PM
drtysohc
Mar 11, 2008 07:47 PM
purplecivicturbo
Suspension & Brakes
Oct 24, 2007 10:57 AM
JimmyAtlantis
12
Nov 18, 2005 01:55 AM
SuperMan19
Mar 6, 2003 01:17 PM
