ITB's and IACV question.
Old Mar 4, 2004 | 08:36 PM
Kendall's Avatar
Default ITB's and IACV question.
First off, yes I searched.
Next, here's my question: If I set the TPS to the "close to stock" settings that people are doing with the GSXR 1000 throttle bodies with the idle set low (like 700 rpms) and then manually adjust the idle so that the TPS registers an idle as not idling but with a low throttle reading (like 5% or something), then can I get away without running an IACV and still have smooth motor operation when I let the car "idle" (which the ECU is reading as slight throttle input)?
Old Mar 20, 2004 | 03:13 PM
machine4321's Avatar
Default Re: ITB's and IACV question. (Kendall)
good question ...i would like to know as well
Old Mar 20, 2004 | 04:45 PM
98HB's Avatar
Default Re: ITB's and IACV question. (machine4321)
Bump
Old Mar 20, 2004 | 04:58 PM
Tbone's Avatar
Buy telling the ecu your at 5% throttle you will be telling it to add more fuel not air like the IAC. Your better off putting a throttle stop in to keep the butterflies open. I'm not suggesting this would be a good thing , but it will work for what your actualy trying to acheive by moving the tps. You need the air to go with the fuel.
Old Mar 20, 2004 | 07:06 PM
na200whp's Avatar
Default Re: ITB's and IACV question. (Tbone)
if you open to much you will have a surging idle simmilar to a vacume leak .
Old Mar 20, 2004 | 07:23 PM
Tbone's Avatar
Default Re: ITB's and IACV question. (na200whp)
Not if the tps is open with it. The tps and map sensor will adjust the timming and the fuel. If you zero the tps at closed(like factory) and just use a throttle stop to crack the throttle slightly it will run at that rpm normally. if you try to trick it your either going to have not enough vaccum or to much fuel.
Throwback23
May 4, 2010 09:33 PM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
zero-one
Feb 14, 2008 04:20 PM
SmogTech01
May 26, 2007 11:31 PM
PHILLIPDEEZ
Jan 24, 2005 06:05 PM
