civic koni yellows
for those of you who has koni yellow shocks on your civics does your rear shocks look like these, if so wat year civic is yours?
if the picture doesnt load the first time just refresh the page and it should load then. thx
what year integra.
you should be able to cross check the part # to find out exactly,
check the part number and email koni,
they have good customer service and should respond fairly quickly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGkwazhimoto »</TD></TR><TR><TD CLASS="quote">eg and teg Same unless it's spring the rate are differnt what year TEG?</TD></TR></TABLE>
spring rates have nothing to do with that mounting point he pictured. 94-01 teg LCA are the same as eg's. you could still use EK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">
94-01 teg LCA are the same as eg's. you could still use EK</TD></TR></TABLE>
The ITR LCAs, at least in the rear, are different so they won't work with other tegs or EGs.
theineffable
Suspension & Brakes
16
Sep 14, 2010 11:28 AM
rmiles87
Suspension & Brakes
Dec 2, 2005 02:51 PM
