is this normal???
Old Mar 4, 2004 | 05:34 PM
imnotswapped's Avatar
Default is this normal???
i have a b16 tranny and i flushed the tranny oil and i needed 4 quarts of oil to fill it back up isnt that alil too much?? oh yea and sometimes when im in 5th gear driving normaly it pops out of gear and goes back to neutral
Old Mar 4, 2004 | 05:37 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: is this normal??? (GoT HaTcH#2)
4 quarts?! Only 2.5 is required.
Old Mar 4, 2004 | 05:40 PM
DOHCtorTHRUST's Avatar
Default Re: is this normal??? (GapxGuy)
2.5? i only put in 1.5Q
kingSfit's Avatar
its either that haha or you engine burns to much oil (^_^) haha
Louie_EM1
Guest
Posts: n/a
There's a fill hole, it should be around 2.2 for a manual tranny I believe.
What is 'the top'????
The fill hole is on there by like a 15mm or a 17mm bolt near your axle.
Old Mar 4, 2004 | 05:41 PM
goula SOS's Avatar
From: Kills Official Truck Quality Assurance Manager, USA
Default Re: is this normal??? (Louie_EM1)
17 mm. I believe it is 2.2 also.
Old Mar 4, 2004 | 05:44 PM
i filled it up from the speed sensor and how come the fifth gear pops out??
Old Mar 4, 2004 | 06:06 PM
anyone??
Old Mar 4, 2004 | 06:18 PM
white ex's Avatar
if you fill it from the speed sensor you still gotta remove the bolt where you would normally fill it , so it starts to pour out. thats how you know when its full..
Old Mar 4, 2004 | 06:19 PM
simplegreenmachine's Avatar
Default Re: is this normal??? (white ex)
you put wayy to much it.
Old Mar 4, 2004 | 06:20 PM
skip.two's Avatar
4 quarts?? way too much
Old Mar 4, 2004 | 06:44 PM
Discosteak's Avatar
Default Re: is this normal??? (MonKey Magic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonKey Magic &raquo;</TD></TR><TR><TD CLASS="quote">you put wayy to much in. </TD></TR></TABLE>
should have taken like 2-2.5 thats the reason it pops out of gear you have too much fluid
Old Mar 4, 2004 | 06:45 PM
Discosteak's Avatar
edit double post
Old Mar 4, 2004 | 06:55 PM
h22avid's Avatar
Default Re: is this normal??? (BADEG6)
Definitely way toooooo much fluid and that is what is causing it to pop out. My H22 only takes 2 qts.
Like others said, you have to remove the fill plug and make sure you're on level ground when you fill it. With the fill plug out, it is impossible to ovefill the tranny because it will simply run out of the fill hole once it's full.
Old Mar 4, 2004 | 07:01 PM
JBONES's Avatar
OPPPPPPPSSSSSSS!!!!yeah i will have to agree with them.....way to much fluid, and it will cause it to pop out!!!
good luck chief, drain some of that fluid and you'll be rock'n!!!!
Old Mar 5, 2004 | 06:41 PM
Default Re: is this normal??? (JBONES)
drained the extra oil but still pop out of fifth gear when driving plz help!!! thanks guys
Old Mar 5, 2004 | 08:19 PM
snoochtodanooch's Avatar
my vote is that your trans is going. Was it whinning real bad before you put in the new oil? did you replace an axle recently or anything. some more info on anything done with the trans would help. I have known people replace axles and not realize that the oil spilling out went into the trans, and not put any extra back in.
Old Mar 5, 2004 | 08:32 PM
Default Re: is this normal??? (snoochtodanooch)
i just bought that motor and installed it i replaced the ring for the axle and theres no whine to it
Old Mar 6, 2004 | 04:14 AM
h22avid's Avatar
How did you drain the oil from the tranny? Too much oil or very low to no oil will cause you to pop out of gear like you describe. Did you pull the fill plug on level ground and just let it drain out there until it stopped?
Trust me I have personal experience with the low oil scenario. When I put my motor in a couple of us were working on it and we all neglected to fill the tranny with oil.... real dumbass thing to do but **** happens. Anyhow lets just say my tranny is bullet proof because I drove with no oil and it popping out of 5th gear for a couple days before I realized what had happened. I pulled the drain plug and to my dismay it was bone dry, not even a drip... I almost **** myself and got that sinking feeling that I was going to be buying a new tranny. Anyhow, I filled it to the fill hole and it has been fine ever since.
Old Mar 6, 2004 | 04:40 AM
RICE POLICE SIP's Avatar
Default Re: is this normal??? (h22avid)
LOL.... who told you to fill it through there... just fill it through the fill port and fill until it pours out... should take around 2 ish....
Old Mar 6, 2004 | 05:49 AM
GdmLaz's Avatar
yup 4 way 2 much
Old Mar 6, 2004 | 06:02 AM
h22avid's Avatar
Default Re: is this normal??? (CRUISIN' TOPLESS)
I've heard of a lot of people filling it through the VSS hole but I wouldn't. It seems like more of a pain that way. I would just pull the fill plug like your supposed to. Not sure why people fill it that way but hey each to their own right
stuck_in_the90s
Aug 19, 2009 04:22 PM
wunfstgsr
Feb 28, 2008 01:33 PM
redracer1024
Jan 25, 2006 12:13 PM
Reason01
39
Feb 4, 2005 03:42 PM
hondaeg8
23
Nov 11, 2004 07:05 PM
