Sick of paint chipping and rust on your coilovers/springs?
Old Mar 4, 2004 | 03:50 PM
5thgencivic's Avatar
Default Sick of paint chipping and rust on your coilovers/springs?
I made the jump and bought some used Skunk2 Coilovers. Finally some support instead of dragging *** everywhere with the stock suspension. Anyway, there were quite a few spots where the paint had chipped off and surface rust had started. Instead of leaving them, I decided to try some Krylon Zinc Rich primer and get the spots covered up. When I used to work around steel we would use zinc primer quite a bit(cold galvanizing). And it always held up well on the I-Beam welds.
I used the dremel with the wire wheel and some sandpaper to prep them. Then I covered up the part of the spring I didn't want painted with a rag and heavy 2 coated everything. Came out pretty good. Better than nothing I guess
Before(after wirebrushing)
After
Old Mar 4, 2004 | 04:15 PM
kingSfit's Avatar
looks great ill try
Old Mar 4, 2004 | 04:34 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (Bunz)
Powdercoating works better, although it's pretty expensive and not everyone knows how to do it. If you have an oven and a source of electricity you can powdercoat.
Old Mar 4, 2004 | 05:07 PM
Jonas99's Avatar
Default Re: Sick of paint chipping and rust on your coilovers/springs? (5thgencivic)
now we need something to keep the sleeves' threads dirt/sand free...
nice DIY, are you painting the primered spots red to match the rest?
Old Mar 4, 2004 | 05:19 PM
Brewer's Avatar
Default Re: Sick of paint chipping and rust on your coilovers/springs? (Jonas99)
Beautiful
Old Mar 4, 2004 | 05:44 PM
huntarrr's Avatar
what happens whent he coil flexes? won't the primer chip off as well?
i'd like to see them after a couple of hundred miles and see how they hold up. looks good though
Old Mar 4, 2004 | 05:59 PM
GetawayInMoscow's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Powdercoating works better, although it's pretty expensive and not everyone knows how to do it. If you have an oven and a source of electricity you can powdercoat.</TD></TR></TABLE>
Powdercoating sucks ***. Once it chips the rest comes off so easily making it worthless.
I would never pay to have anything powdercoated.
Old Mar 4, 2004 | 06:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonas99 &raquo;</TD></TR><TR><TD CLASS="quote">now we need something to keep the sleeves' threads dirt/sand free...
nice DIY, are you painting the primered spots red to match the rest?</TD></TR></TABLE>
Yea grit on the threads bites. These were caked.
I'll just leave it primered. Thanks.
Old Mar 4, 2004 | 06:53 PM
jdmgeorge's Avatar
that zinc stuff works great
preludepower01
Paint and Body
Apr 21, 2011 05:25 PM
preludepower01
Apr 19, 2011 11:01 PM
iheartmyej8
Feb 15, 2009 04:37 PM
scsikid
Suspension & Brakes
Mar 27, 2006 04:31 AM
Xx D-MAN xX
Mar 2, 2004 11:00 AM
