*Searched* High Idle after STR throttle body.
Old Mar 4, 2004 | 02:46 PM
FlatLineEG8's Avatar
Default *Searched* High Idle after STR throttle body.
I see all these other problems are solved with the fast idle valve or IAC, i replaced my iac, i dont think i have the fast idle thing anymore. Bled coolant, checked vacuum hoses, adjusted cable, adjusted TPS to .45V, still idles at about 1100 rpm. I changes the TB gasket also. Any suggestions? its a JDM B16 in a 92 4door.
Old Mar 4, 2004 | 03:02 PM
EPGONZALEZ's Avatar
Default Re: *Searched* High Idle after STR throttle body. (FlatLineEG8)
alot of aftermarket tbodies have poor seals at the butterfly.
Old Mar 4, 2004 | 03:07 PM
B18C4-T's Avatar
I had the opposite problem, my car wouldn't idle. I called STR and they said to adjust the idle screw under the throttle linkage. There is a small allen screw w/ a nut on it under the throttle cable, loosen the nut and adjust the screw up or dowm until it idles where you want it. Make sure you tighten the nut back down after the adjustments. Larry
Old Mar 4, 2004 | 04:47 PM
Civic_95_Si's Avatar
Default Re: *Searched* High Idle after STR throttle body. (B18C4-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C4-T &raquo;</TD></TR><TR><TD CLASS="quote">adjust the idle screw under the throttle linkage. There is a small allen screw w/ a nut on it under the throttle cable</TD></TR></TABLE>
I had high idle after I got my thorttle body. I took it back to the shop and my mechanic messed with some little screw. I'm guessing its the same one.
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
asocallocal
Sep 23, 2010 06:20 PM
emooheo
Mar 23, 2007 02:34 PM
631 Teggy
14
Nov 23, 2005 09:11 AM
wantmorepower
Aug 21, 2001 12:08 PM
