itr in 88 hf
this maybe a newbie question but ive searched and cant find it out maybe i didnt search hard enough.. a simple yes or no will do..Which tranny should i use with a obd2 block in a 88 hf crx .. I know what fits in there is a cable and a hydro can be made to work (with appropriate mounts, and im sure other things as well). basically can an obd1 tranny work with a obd2 motor
all b series stuff will mate up...you could take a 1st gen b16 block and mate it to a cable or hydro ls or gsr or itr tranny or vice versa. Being that you have a cable-clutch chassis I would look for a cable b16 tranny with a lsd already installed (I recommend a quaife
thats what i thouhgt ..just wanted some clarification..thanks as far as wire harness goes, would i want to use aobd1 or obd2 harness or is there even a difference?(for example a b16a1 harenss or a 2nd gen b16 harness..is there any difference
blade0314
Apr 8, 2008 10:10 AM
PURO~SURCAL
Mar 1, 2006 02:07 PM
