will i pass smog?
Old Mar 4, 2004 | 10:19 AM
DubyaAye's Avatar
Default will i pass smog?
will i pass smog for not plugging that sensor (or whatever you call it) in? its time for smog and gots to take out my turbo and borrow a intake with the carb sticker and notice the sensor dont fit.
Old Mar 4, 2004 | 02:35 PM
DubyaAye's Avatar
Default Re: will i pass smog? (DubyaAye)
anybody?
Old Mar 4, 2004 | 05:32 PM
Fobtions's Avatar
drill a hole in the intake, and stick it in.
Old Mar 4, 2004 | 06:56 PM
bayarea13's Avatar
with the intake air temp disconnected you may or may not fail. you should fail visual, but you may not. you will fail if the sensor is disconnected from the harness almost for sure. evap monitors are dependant on IAT, they run normally relative to IAT and ECT being close in value. i have seen cars not running monitors due to bad or disconnected IAT's. also if it is disconnected it will probably set a DTC for low or no IAT signal. you can try leaving it connected but not in the intake, and hope they dont notice.
Old Mar 8, 2004 | 11:45 AM
Billy Blaze's Avatar
Default Re: (bayarea13)
No, you will fail smog unless your ambient air temp sensor is hooked up.
Old Mar 8, 2004 | 11:26 PM
DubyaAye's Avatar
Default Re: will i pass smog? (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">drill a hole in the intake, and stick it in. </TD></TR></TABLE>i would but its not my intake so i cant.
cvc1393
Jul 19, 2009 01:19 PM
PHILEE
Mar 15, 2008 10:18 AM
sn00py415
19
May 7, 2007 08:02 AM
xjun10rx
May 13, 2004 01:04 AM
maderfacker
Jul 21, 2002 11:12 AM
