smog question.. help!!!1
Old May 12, 2004 | 02:39 PM
xjun10rx's Avatar
Default smog question.. help!!!1
hey whats up... ok this is my question.. can i pass smog with v2 intake dc headers greddy sp 3exhaust?????? also my crankshaft speed fluktuator sensor is bad... i have a check engine light because of this.... so can i pass smog because of this???? what should i do???
Old May 12, 2004 | 02:43 PM
SuzukaBlueAP2's Avatar
Default Re: smog question.. help!!!1 (xjun10rx)
Well, if you have more than one header....I doubt it.
I don't know how much the CKF sensor will affect your smog, but I would certainly get that checked out. Should it not be the sensor that is bad, and the sensor is actually sensing something wrong with the crank, that could be bad.
I guess to know for certain, you'll have to get the car SMOG checked and find out. If it doesn't pass, aren't there things you can add to the fuel and it will supposedly help you pass? Plus, it's a snap to install the factory intake.
Old May 12, 2004 | 06:22 PM
xjun10rx's Avatar
well i have i/h/e and their all carb legal.. so the v2 intake is legal... just want to know what is up with the CSF senors. ... if not fixed can it affect the smog??? what u mean about the headers??? so does anyone know??? thanx for replies
Old May 12, 2004 | 06:38 PM
xjun10rx's Avatar
anyone help.....
Old May 12, 2004 | 07:00 PM
SMZ GSR's Avatar
Default Re: (xjun10rx)
I would recommend just fixing the problem. I believe some smog places wont smog the car if there are CEL's
Old May 12, 2004 | 07:05 PM
TurboxDC2's Avatar
u wont pass if u have a CEL on...the intake and exhaust should be fine...i failed with my DC headers...i would fix the CEL and put on the stock headers before going to smog it.
Default Re: (SMZ GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR &raquo;</TD></TR><TR><TD CLASS="quote">I would recommend just fixing the problem. I believe some smog places wont smog the car if there are CEL's</TD></TR></TABLE>
Oh yeah, totally forgot about that. ^^^ He's right. They may not even check it if the CEL is on.
Did you pull the code for sure to see what it is?
Old May 12, 2004 | 07:14 PM
xjun10rx's Avatar
yeah pulled the code i think it was 65 witch is the crankshaft speed fluktuator sensor...... hey why didnt u pass with ur dc sport headers???/ if they are carb legal??...
Old May 12, 2004 | 07:16 PM
Code 65 is the secondary O2 sensor circuit.
If I were you, I'd re-check to see what code it is throwing.
Old May 12, 2004 | 10:10 PM
xjun10rx's Avatar
then its 54 cuz i had 2 codes come up but i fixed the 02 one... so now i need that other one... so does anyone think ill pass with that cel&gt;&gt;??? and why dont dc headers pass??? if they are carb legal...
Old May 12, 2004 | 10:27 PM
Sack Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xjun10rx &raquo;</TD></TR><TR><TD CLASS="quote">so does anyone think ill pass with that cel&gt;&gt;?? and why dont dc headers pass??? if they are carb legal...</TD></TR></TABLE>
With the headers, it's probably a combination of things. I would imagine most likely. Thin guage steel as used in these headers lets the heat escape. So the exhuast charge is not as hot as it should be. Either the cat is not working properly, the car wasn't run hot enough before smogging, or if it's a high-flow cat which will probably never pass smog either. It very well could be something else is wrong too.
As for your CEL. Maybe with any luck the smog tech will disreguard the light or not see it. But he's not supposed to pass a car with a CEL.
Old May 12, 2004 | 10:35 PM
xjun10rx's Avatar
well i have to take it to a smog only station.. and i took it the other day and he sayd to fix the o2 sensor and other check engine light... he said he can run it like that but he doughts it will pass it so he said to come back once it is fixed...
Old May 12, 2004 | 10:47 PM
xjun10rx's Avatar
bump bump help me
Old May 13, 2004 | 01:04 AM
xjun10rx's Avatar
bump for the night
PHILEE
Mar 15, 2008 10:18 AM
ninjlao
May 18, 2005 12:16 PM
R.a.w.
Oct 16, 2004 07:16 PM
DubyaAye
Mar 8, 2004 11:26 PM
