how to tell if my v-tec solenoid is work and y my v-tec isn't working
Old Mar 4, 2004 | 09:02 AM
racingant's Avatar
Default how to tell if my v-tec solenoid is work and y my v-tec isn't working
how can i tell if my v-tec solenoid. I was told to run a wire to the solenoid and rev up the motor and tap the other end of the wire to the battery will that make the v-tec kick in if so i did that and it doesn't kick in but i hear the solenoid clicking or do i have to drive it to make it work that way
I also get the msd actrpm switch and ran that with the relay and did the same they by rev up the motor and still nothing or do i have to drive the car to make it kick in
can some tell me what i'm doing wrong please thanks
Old Mar 4, 2004 | 09:07 AM
crx_88_si's Avatar
do you have ANY cel's ?
Old Mar 4, 2004 | 09:08 AM
91civicDXdude's Avatar
if the solenoid is clicking, its working.
I would try a few things... check your oil level, & your oil pump if its a stock VTEC engine.
Also, remove the VTEC solenoid and clean the screen inside if it's dirty.
If this is a SOHC mini-me VTEC engine, make sure that you removed the oil control jet in the block.
Old Mar 4, 2004 | 09:16 PM
racingant's Avatar
Default Re: (91civicDXdude)
what is cel's
Old Mar 4, 2004 | 09:31 PM
B2FiNiTY's Avatar
Default Re: (racingant)
check engine light = CEL
Old Mar 5, 2004 | 12:54 AM
sohcvtec66
Guest
Posts: n/a
Default Re: (B2FiNiTY)
i think i might have the same prob, car has to be fully warmed, but no code'...no clicking
Old Mar 5, 2004 | 06:00 AM
KnowForever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
yes, definatly try this.. most likely your problem and simple to check
Old Mar 5, 2004 | 07:07 AM
90 SiR Hatchie's Avatar
Also try your TW sensor, but thats only if your car is ideling bad.
Old Mar 5, 2004 | 07:59 AM
hybrid1990crx's Avatar
Default Re: how to tell if my v-tec solenoid is work and y my v-tec isn't working (racingant)
You guys should of atleast answered this one MAIN question first.
Yes, your car WILL NOT enguage vtec when reved in neutral. It must be moving.
Old Mar 6, 2004 | 06:43 PM
racingant's Avatar
Default Re: how to tell if my v-tec solenoid is work and y my v-tec isn't working (hybrid1990crx)
thanks for the help will drive and see and will also clean it thanks to all
Old Mar 6, 2004 | 06:58 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid1990crx &raquo;</TD></TR><TR><TD CLASS="quote">You guys should of atleast answered this one MAIN question first.
Yes, your car WILL NOT enguage vtec when reved in neutral. It must be moving.</TD></TR></TABLE>
he's saying the ECU needs to have a spedo pulse, either VSS electronicly, or witht he speedo cable, and the current from the cluster to the ECU.
(wheels have to turn for VTEC)
Old Mar 6, 2004 | 08:14 PM
Jet Black's Avatar
Really? Even if you short the solenoid on???? Seems to me if it has oil pressure and the solenoid goes on, VTEC will kick in.
Old Mar 6, 2004 | 08:49 PM
Built B16A's Avatar
Default Re: how to tell if my v-tec solenoid is work and y my v-tec isn't working (Jet Black)
if you short a light bulb, it will go on.
the ECU controlles the VTEC sol.
if you short the sol. on hot, provided they're is oil press. pressent, it should be active.
sol. ran hot.. with oil press, NO VTEC.. could mean clogged screen, or ultimatley, missing VTEC pins inside the individual rocker arms. (last resort) belive me, ive seen it happen.
BlueSmartEm1
13
Jul 3, 2011 09:26 PM
swizz977
10
May 25, 2011 08:15 PM
MyIntegra
Jun 12, 2009 10:54 AM
DougNuts
Jan 19, 2008 01:16 PM
DsBananas94LS
Dec 5, 2004 07:51 PM
