Help asap..do i need a resistor box
im gettin ready to put a jdm h22a in my civic. i ahve heard i do and dont need one....teh harnessi got with it was pretty complete, although i saw nothing liek a reisistor box....any help guys...the motor should go in any day, but i want to know if i need to look for them
thanks
oh and i already searched, but coulnd find an exact answer
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro »</TD></TR><TR><TD CLASS="quote">you mean for the injectors... I am not 100% on the JDM's but IIRC all the USDM's do need them. Just look to see if they are high or low impedence. </TD></TR></TABLE>
Is it OBDI?
Is it OBDI?
if its obd1 jdm h22a you got 345cc peak and hold, meaning you need a resistor box. If its obd1 usdm h22a then they are peak and hold also but i'm not sure if they are the 345s or not, i've got a resistor box if you need one, 20 shipped
where you at in ohio compaired to findlay, i could drop by and help you out, resistor box look like a very small amp, its got heat sinks on it, made out of aluminum, and has 5 wires coming out, you can put it where ever you wwant in your bay, on the harness it will be kind of close to the injector plugsit will have a plug where it can be disconnected from the harness also, i'll try to get pics tonight, i had to wire it in my h22 teg
mrrugsr
Mar 24, 2006 07:12 PM
edit: looked it up
