LS VTEC NEED INPUT
Old Mar 4, 2004 | 06:01 AM
99 TYPE R's Avatar
Default LS VTEC NEED INPUT
i just picked up a 96 ls motor for $300 i wanna rip it apart and build ls vtec and maybe turbo it for first what crank and rods bearings pistons etc.. should i get to run a 11.5 to 12.5 CR , i have a type r head for it and i will be ordering the ls vtec kit , can u techs recomend what i should do , it will be in a 93 hatch , put it this way i wanna run 12.50's-13.0's with street tires please recomend suming thanx guys
Old Mar 4, 2004 | 06:10 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: LS VTEC NEED INPUT (99CtRdAvESI)
you can run 12.5-13:1 cr IF you have a good tuner on pump gas, 92+ octane. but you first need to make up your mind if you want to go forced or all motor as far as your compression is concerned. use your ls crank, and oem honda bearings are the way to go.
Old Mar 4, 2004 | 06:56 AM
10seceg's Avatar
Default Re: LS VTEC NEED INPUT (vtecb20coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">you can run 12.5-13:1 cr IF you have a good tuner on pump gas, 92+ octane. but you first need to make up your mind if you want to go forced or all motor as far as your compression is concerned. use your ls crank, and oem honda bearings are the way to go. </TD></TR></TABLE>
I concur
Old Mar 4, 2004 | 08:13 AM
99 TYPE R's Avatar
should i get the crank knife edged or polished and what pistons should i use , im positive i wanna go turbo ,recomend a the bottom end to be set for @10psi what compression, and should i get the block decked or machine or honed
Old Mar 4, 2004 | 08:37 AM
B A N N E D
Default Re: (99CtRdAvESI)
knife edging and polishing the crank is not necessary. however, you should get the block checked for roundness and then have it either bored or honed.
Old Mar 4, 2004 | 10:39 AM
99 TYPE R's Avatar
will the machine shop decide what to bore it out to or do i decide
ek4ferrio
Oct 6, 2006 10:14 PM
cartel420
Jun 26, 2006 03:17 PM
stylin-teg
Dec 9, 2004 08:13 PM
camera obscura
18
May 26, 2003 03:56 PM
