Cam choice need input
Crower 403 or skunk2 stage 2 or 3......
I am at 190wh with cat cams (ctr) kind of.....ctr pistons...etc etc
I want 205-210.....what cam can bring me up higher, the enigne is built.....
News for you guys - the JUN3 is not a high rpm profile
You shouldn't run past 9200 rpms with the a JUN3 or Skunk's version stage 2. So if you don't plan to run past this point this is a good choice. This profile has a fast ramp and will sign off before skunks stage 3 profile (smoother profile) but makes better power below 8k rpms.
I have profiles with similiar performance to both mentioned above as well.
Jun cams are great cams ive seen many motors with Jun cams peak well over 9500 rpm... Rs cams are the best cams ive seen so far as in mid range and top end power...
Does anyone have proof that RS cams out perform the above listed?? I've been hearing this over and over again with no evidence to back this claim! Can someone refer me to a link with dyno comparisons or something?
