how to tell what type-s cams to get
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Slow Lude »</TD></TR><TR><TD CLASS="quote">can you only tell if you need A's or B's when you open the block up???
what this nonsence....</TD></TR></TABLE>
I dont get it.........
grrr.... i meant pistons i was just so mad at hearing that news i typed real quick.... my bad
anyway can someone enlighten me on this......
they MIGHT use different size pistons in the same motor.... it sounds redickulous
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Slow Lude »</TD></TR><TR><TD CLASS="quote">they MIGHT use different size pistons in the same motor.... it sounds redickulous</TD></TR></TABLE>
It's not ridiculous, it is how they deal with differing tolerances during the manufacturing process. An "A" bore requires an "A" piston, a "B" bore (which will be slightly different in size than "A") requires a "B" piston.
b20vtech
10
May 22, 2008 10:09 AM
hype_R
Mar 7, 2008 08:37 AM
