Dustin: What did you use for you test pipe?
Old Oct 15, 2001 | 10:01 PM
Etylorcen's Avatar
Default Dustin: What did you use for you test pipe?
^^^^^ From your install pics it looked like a cheap easy solution.
Old Oct 15, 2001 | 11:07 PM
Anthony K's Avatar
New User
Default Re: Dustin: What did you use for you test pipe? (Etylorcen)
He used a flexpipe from an exhaust repair kit (2.5") and had a flange made to fit the cat back exhaust. I've actually seen it in person. I'm sure there's a little more to it, but that is the basics of it all.
Old Oct 16, 2001 | 06:07 AM
dbman96's Avatar
New User
Default Re: Dustin: What did you use for you test pipe? (Anthony K)
yah you need to put in a bung for at least the primary O2 sensor
Old Oct 22, 2001 | 07:12 PM
Etylorcen's Avatar
Dustin?
Old Oct 22, 2001 | 07:15 PM
Anthony K's Avatar
New User
uh, why don't you read my post? I actually own Dustin's test pipe now. It's on my car as we speak. Basically, get a 2.5 inch flexpipe (exhaust repair kit), then have a flange made to fit your cat back exhaust bolts. One end will hold the bolts, the other will be pushed inside the flexpipe.
Old Oct 22, 2001 | 07:35 PM
Etylorcen's Avatar
Default Re: Dustin: What did you use for you test pipe? (Anthony K new boost junky)
Well you said there was a little more to it so I just wanted to know from him what exactly was the little more. Where did you get the flange that'll fit the cat?
Old Oct 22, 2001 | 07:45 PM
Flamenco-T's Avatar
any muffler shop can get you the flange made, just ask for a 3 bolts 2.25-2.5" diameter flange and have them weld it to a 2" piping with 2.25 or 2.5" diameter...
then get the exhaust repair kit, clamp the flex pipe to the welded flange...
now, if your car is an OBD 1 (96 or older) you're fine....
if you're OBD II (96-newer), you'll need to weld in another O2 sensor bung anywhere in the downpipe, stay close to the end, since you have a limited amount of O2 sensor wires to be able to reach...
for the O2 sensor bung, go to any muffler shop and have them do it...
I believe Dustin's GSR is an OBD I, so his is pretty much bolt up and go..
Old Oct 22, 2001 | 09:02 PM
Anthony K's Avatar
New User
Default Re: Dustin: What did you use for you test pipe? (flamenco)
Or if you have OBDII, you can unplug the second O2 sensor, bring it inside the car and plug it back in around the area behind your stereo, wrap it in aluminum foil, and secure it.
Old Oct 23, 2001 | 08:41 PM
Etylorcen's Avatar
Will i throw codes like that?
Old Oct 23, 2001 | 08:42 PM
dustin's Avatar
No.
Old Oct 24, 2001 | 05:06 PM
Etylorcen's Avatar
Default Re: Dustin: What did you use for you test pipe? (dustin)
How do you get the o2 sensor back into the cabin to wrap it up?
Also, did you notice with this test pipe its pretty loud from up front? Don't really hear much from the exhaust, maybe its the wastegate.
Old Oct 24, 2001 | 05:10 PM
dustin's Avatar
It is the wastegate.
Old Oct 24, 2001 | 05:21 PM
Etylorcen's Avatar
Im using the 10'' piping that came with the drag kit to route the wastegate's gases downward, do you think if I extend that piece toward teh bottom of the car it'd quiet it up?
Old Oct 24, 2001 | 05:23 PM
dustin's Avatar
No.
Old Oct 24, 2001 | 06:57 PM
Anthony K's Avatar
New User
Unplug the secondary O2 sensor and take it off the cat. Wrap the sensor up nicely in aluminum foil and bring it inside the car. Inside the car, crawl inside and pull the carpet up from behind the area where the stereo is located. Look for the plug that it originally plugged into and bring it through. Plug the O2 sensor back in and secure it in place.
Old Oct 24, 2001 | 07:07 PM
quikrpm'z's Avatar
or just zip tie it underneath the car.
Old Oct 24, 2001 | 07:09 PM
dustin's Avatar
Default Re: Dustin: What did you use for you test pipe? (quikrpm1)
No reason to allow the sensor to be exposed to the elements.. At least not the actual 'sensing' part.
Old Oct 24, 2001 | 07:22 PM
degradated's Avatar
New User
This will stop the car from throwing a check engine light code, right?
What do you think I should do since I had a bung welded into my test pipe already for this 2nd 02 sensor. What can I plug the bung with...any ideas? I'm thinking of just buying a large screw with the same size thread and just screwing it into the bung to seal it off, if this would be sufficient.
Old Oct 24, 2001 | 07:36 PM
Mr. Vapor's Avatar
Default Re: Dustin: What did you use for you test pipe? (degradated)
yea that will work, or you can JB Weld it. if you pop a bolt in there, you might wanna teflon it
Old Oct 24, 2001 | 07:47 PM
dustin's Avatar
Default Re: Dustin: What did you use for you test pipe? (NYb16)
A bolt will hold just as good as an O2 sensor
I would do the bolt. Then someday you can put a wideband O2 sensor in there for when you are on the dyno
Dustin
Old Oct 24, 2001 | 07:57 PM
Anthony K's Avatar
New User
My car has avoided the CEL from this so far. It works good.
Another_Si_Guy
11
Dec 7, 2015 08:44 AM
allmotrDC2
Nov 16, 2005 01:58 PM
Teg4e
May 29, 2002 10:41 AM
Bs
May 27, 2002 01:27 AM
Etylorcen
Oct 23, 2001 11:55 AM
