what's the avg. compression # for a 1st gen b16 motor?
Tried a search but couldn't find the numbers for a b16. Anyone done a compression test on their motors, post your numbers.
that's cool. I got 180psi on 3 cyclinders and 165 on the 2nd one. I guess it'll drive for a while. Thanks.
I got 175 accross all 5 when it was cold. It should a be a little higher when the motor is warm. What you should look for is consistancy (as long as its not 45 psi on all 4 cylinders)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- »</TD></TR><TR><TD CLASS="quote">I got 175 accross all 5 when it was cold. It should a be a little higher when the motor is warm. What you should look for is consistancy (as long as its not 45 psi on all 4 cylinders)</TD></TR></TABLE>
all 5?
all 5?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -KangaRod- »</TD></TR><TR><TD CLASS="quote">I got 175 accross all 5 when it was cold.</TD></TR></TABLE>
When did Honda start making a 5 cylinder motor?
Mine was 210-195-205-185, as long as the numbers are within 10% of each other you should be fine. Also make sure the tester has been calibrated or is new.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Furball »</TD></TR><TR><TD CLASS="quote">
a legend has a 5 cyl.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speed_racer012 »</TD></TR><TR><TD CLASS="quote">what legend?</TD></TR></TABLE>
Acura Legend....
-Eric
Acura Legend....
-Eric
Acura Vigor has a straight 5 cylinder.
yeah but still, were talking about the b16 here, which is 4cyl, not a 5cyl, so why would he even put what his compression results were with his 5cyl, shoulda just said to look for consistency.
Unless it ways a typo
-Eric
-Eric
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">
Acura Legend....
-Eric</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shivic »</TD></TR><TR><TD CLASS="quote">
Acura Vigor has a straight 5 cylinder.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J Money »</TD></TR><TR><TD CLASS="quote">The Acura Vigor had a five cylinder engine. </TD></TR></TABLE>
First of all I think all of you need to read my post again, it says HONDA, acura is a branch off of the family but it is not a HONDA.
Acura Legend....
airslammedcivic2
Apr 8, 2010 12:18 AM
