re-locating battery to trunk
Old Mar 2, 2004 | 07:22 PM
7808's Avatar
Default re-locating battery to trunk
i was thinking about relocating my battery to the trunk for more room for piping, anyone done this and where have you found is a good ground?
i'll probly be using a optima
Old Mar 2, 2004 | 07:46 PM
Firedrake's Avatar
Default Re: re-locating battery to trunk (fuctup)
I'm using one of the 3 shock bolts as a ground, just make sure you grind off the paint around that area so it gets a good connection.....
Old Mar 2, 2004 | 08:37 PM
RAB's Avatar
RAB
Default Re: re-locating battery to trunk (Firedrake)
Search I did an extensive thread related to exactly what you're asking.
Old Mar 5, 2004 | 10:53 PM
7808's Avatar
Default Re: re-locating battery to trunk (RAB)
anyone tried this on a 4g prelude? i looked and didnt really see a spot....
Old Mar 6, 2004 | 06:35 AM
madcatz's Avatar
that is a Db Drag car, prolly NOT DRIVEN on the street. Water + Oxygen = Corosion, which is rust and such. Anyways not enough room under the car to do it, les you pound up the trunk lining area. You plan on going turbo, why do you want to add the extra weight, or you just a dumb street runner, light to light....go play russian roulette
Old Mar 6, 2004 | 07:07 AM
RAB's Avatar
RAB
Default Re: (madcatz)
Water and flowing electricity DO NOT mix well. There's a good reason why the make marine boxes for boats.
Old Mar 6, 2004 | 07:28 AM
Greyout's Avatar
Default Re: (RAB)
I drilled a hole through the sheet metal panel that the jack sits behind, then used a bolt w/ a giant washer.
btw, relocating the battery makes a huge difference & makes the car handle much better
Old Mar 6, 2004 | 05:47 PM
solowerks's Avatar
i just finished up relocating mine tonight..I just grounded it underneather the spare tire with some 4 gauge wire and a bolt...everything works great
Old Mar 6, 2004 | 07:37 PM
7808's Avatar
Default Re: (solowerks)
that car has a huge turbo - im guessing the plexi windows are for wieght reduction- so they probly do drive it on the street, and arent optimas supposed to be damn near indestructable? i know water and electricity dont mix, id make a sealed cover for the terminals, i was just wondering if anyone had any luck finding a spot under there car, cause i need the room up front for piping and i already have a 10lb nitrous bottle and a 12" in my trunk.
and im not a dumb street racer going light to light whatever the fuc thats about. i dont even race people, stuff i do to my engine is more for fun, unlike some people i know my car isint fast and the turbo is more like a project just to gain knowledge
edit: actually i did race my friend in his 95 civic ex twice one time.. it was pretty even tho but i had a fat kid in my car - and i didnt shoot the juice
Old Mar 6, 2004 | 07:50 PM
madcatz's Avatar
still take my last line of advice.
You either want speed or show....you cant get the best of both less you have a fat wallet, and as much as I love preludes, hell I have the cursive logo on my left leg below my knee, you should have bought a faster car if you want speed, Turbo will drain your wallet fast on a honda, so there is your weight reduction, and a Drag racer WONT USE OPTIMA they weigh too much, they will either pick up some dinky lil battery or do whatever, but a drag car is ment to get rid of weight, not build a system that you need Plexiglass for, and most the time drag cars use lexan, lighter
Old Mar 6, 2004 | 09:25 PM
madcatz's Avatar
oh yeah see that lil blue thing on the top of your Race car CRX, I believe that is a Db counter. I may be wrong, but im 95% sure thats a Db counter, once again proving your wrong about that car being a raceer
Old Mar 7, 2004 | 07:30 PM
d98clturbo's Avatar
not a prelude but here
http://f1.pg.photos.yahoo.com/...0.jpg
rich7777
Jul 27, 2011 11:04 PM
CRXherbie91
May 14, 2008 05:10 AM
ridiculous
Nov 13, 2002 11:52 AM
redciv
Aug 20, 2002 09:37 AM
DAYUIZ
Dec 27, 2001 05:32 PM
