DOH! rod/cap direction
Old Mar 2, 2004 | 07:14 PM
kaj's Avatar
kaj
Default DOH! rod/cap direction
okay. i'm a dumb ***. i pulled the piston/rod out without marking which way the cap faced on the rod.
i noticed the the rod and cap each have notches in them:
so, am i to assume the notch in the cap goes on the opposite side as the one on the rod?
if i put them on the same side, they don't match...
Old Mar 2, 2004 | 07:35 PM
the DR.'s Avatar
Default Re: DOH! rod/cap direction (kaj)
the notches go on the same side (you can tell by the imprint it left)
Old Mar 3, 2004 | 12:37 AM
civicsitek GanGsTa's Avatar
Default Re: DOH! rod/cap direction (the DR.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the DR. &raquo;</TD></TR><TR><TD CLASS="quote">the notches go on the same side (you can tell by the imprint it left)</TD></TR></TABLE>
Old Mar 3, 2004 | 03:21 AM
kaj's Avatar
kaj
Default Re: DOH! rod/cap direction (civicsitek GanGsTa)
:werd: sweet. i'd hate to put it in and be pissed 'cause the bearings were wearing wrong. thanks!
so they both go on the same side of the piston (intake or exhaust.. if forget which) .. but the don't touch, right? 'cause they are on different sides of the bearing.
same side, the rod side faces down on one side, the cap faces up on the other. confusing sounding, but am i right?
i see the imprint in the pictures. thanks again, guys.
Old Mar 3, 2004 | 05:01 AM
Dan GSR's Avatar
also if you look at the side of the rod, you will se a number stamped, if you put the cap on the right way, the number will show up completely, otherwise the number will be half cut off
Old Mar 3, 2004 | 08:47 AM
kaj's Avatar
kaj
Default Re: DOH! rod/cap direction (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">also if you look at the side of the rod, you will se a number stamped, if you put the cap on the right way, the number will show up completely, otherwise the number will be half cut off</TD></TR></TABLE>
ooooooh. see, i THOUGHT i checked for something like that and didn't find it. okay, cool. it's a no-brainer.
thanks ya'll! motor will be put back together by sat! i can't wait. thanks again!
EG-SIXV-TEC
Jul 5, 2013 05:20 AM
hondatuning1989
Apr 15, 2008 09:10 PM
stumpyf4
Aug 4, 2007 06:33 AM
pdiggitydogg
Feb 22, 2007 04:29 PM
crx1856
Sep 18, 2003 08:29 PM
