dealing with messed up balljoints?
Old Mar 2, 2004 | 05:44 PM
BIG RICH's Avatar
Default dealing with messed up balljoints?
well, I think there bad. I'm going to replace them later, but right now I want to get the car going. Anyway, I can't tighten the nut down on the lower ball joint without it spinning. I jacked up the lower control arm until the wieght of the car was on it and got one side to tighten up. the other side wasn't so easy, it still won't tighten up. any ideas? I'm also having this problem with one of the tie-rods. any thoughts on that? I could replace that easy, but the ball joints a little harder. thanks
Old Mar 2, 2004 | 06:28 PM
Cory man's Avatar
Default Re: dealing with messed up balljoints? (BIG RICH)
If the shaft that the castle nut fits on is turning, apply load to it. Lower the car on the balljoint when its installed on the LCA. This should take care of your problem. Changing balljts on our cars is pretty easy. You can use a socket to remove and install them. Any other questions PM me. HTH
Old Mar 2, 2004 | 06:56 PM
sabertooth's Avatar
Default Re: dealing with messed up balljoints? (Cory man)
how do u replace ball joints with a socket?
Old Mar 2, 2004 | 07:05 PM
Cory man's Avatar
Default Re: dealing with messed up balljoints? (sabertooth)
You beat them out with a socket. There is a small snap ring that needs to be removed. Once its removed grab a BFH and hammer it out. Once its out you can use the same socket to install it. Some are harder than others but i've done a few with a socket and it works well. HTH
Old Mar 2, 2004 | 07:54 PM
HumanResource's Avatar
I agree with this method
I tried the Ball Joint extractor tool but Pounding the thing out worked best
Just becareful driving it in
Old Mar 3, 2004 | 08:05 PM
bspeed's Avatar
why are you changing them? are they sticking or something?
Old Mar 4, 2004 | 05:35 AM
xxtegra's Avatar
Default Re: dealing with messed up balljoints? (bspeed)
just did this on my teg it took like an hour
the hardest part was putting the new snap ring on
i dint have the right tool
so i made one
Old Mar 4, 2004 | 07:26 AM
virginia_dude's Avatar
two words "AIR TOOLS" use something to leverage them in for grip and inpact wrench can get them on or off.
Kevins89notch
21
Nov 4, 2013 06:17 AM
ammomel
Jan 3, 2011 06:07 AM
chibiko
Jun 6, 2007 08:45 PM
allmotorEG-SI
Apr 17, 2005 05:52 PM
rasinhell
Feb 3, 2005 01:47 PM
