Warped rotors at 16000 miles......
Old Mar 2, 2004 | 05:35 PM
migs's Avatar
Default Warped rotors at 16000 miles......
Anybody else have this problem? I have just over 16000 miles on my 03 Si and I notice the rotors are already warped.
Personally, I think thats kind of crappy of Honda to put rotors on a Civic that warp that fast.
Oh well, Ill just get em turned at work.
Old Mar 2, 2004 | 05:43 PM
Steve26's Avatar
Default Re: Warped rotors at 16000 miles...... (Migs)
that may be because I am pretty sure at 10,000 miles you are supposed to switch them around or something... anyone know the answer?
Old Mar 2, 2004 | 05:57 PM
migs's Avatar
Default Re: Warped rotors at 16000 miles...... (Steve26)
Switch them around? Never heard of that but Im a n00b to EP3's, so englighten me.
Old Mar 2, 2004 | 06:29 PM
Steve26's Avatar
Well... I have no more experience with it than you... just something I know I have read on here... do a search about rotors and you may find something.
Old Mar 2, 2004 | 06:40 PM
mikestypes's Avatar
Rotors can be warped by that time, although my TypeS is going fine at 50,000km on the stock rotors.
Things you want to be careful of to avoid warping your rotors are as follows:
1) Don't drive your car briskly, then pull into the wash bay and spray the hot rotors with water. This rapid cooling will cause them to warp.
2) If you come to a hard stop, or are stopping after driving hard, don't sit at the light with the brakes on and not moving. The rest of the rotor will cool faster than the clamped part under pads, and the rotor will warp.
Old Mar 2, 2004 | 06:59 PM
kseriesDC5's Avatar
Default Re: Warped rotors at 16000 miles...... (mikestypes)
brake upgrade ? brembo
Old Mar 2, 2004 | 07:16 PM
eg_nezay's Avatar
Default Re: Warped rotors at 16000 miles...... (kseriesDC5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kseriesDC5 &raquo;</TD></TR><TR><TD CLASS="quote">brake upgrade ? brembo</TD></TR></TABLE>
No Brembos for the EP yet, unless you do the 5lug conv.
Old Mar 2, 2004 | 07:23 PM
eg_nezay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Migs &raquo;</TD></TR><TR><TD CLASS="quote">Anybody else have this problem? </TD></TR></TABLE>
I think he ment have them turned, instead of switch. You shouldnt have to at the mileage though.
Mine were fine before I changed them Mike.
Old Mar 2, 2004 | 07:40 PM
CHILIBEANZ's Avatar
acura has a service bulletin out in reference to this same type of problem. the problem with the acura rotors are that they are scoring prematurely. check with a service rep before u do anything to see if they'll cover it under warranty.
Old Mar 2, 2004 | 10:27 PM
vpforeva's Avatar
New User
Default Re: (p220)
unproperly tightening the lugnuts will also cause warped rotors
Old Mar 3, 2004 | 01:02 AM
pints99's Avatar
Sounds like a good excuse for some aftermarket rotors.
Old Mar 3, 2004 | 05:56 AM
f1nal zeros's Avatar
I ate through my rotors in 4 months.. well that was because I was using Cobalt Friction's GT-Sport brake pads as a daily driver. hahah. I now have my rotors turned and they are fine once again, but I also needed new brake pads.
lude98SH
Feb 18, 2008 06:38 AM
S2Kricer
11
May 12, 2006 03:01 PM
snatch
Nov 18, 2005 08:19 AM
ek44
Apr 25, 2004 08:04 PM
mechengine
Apr 3, 2004 10:48 PM
