F22a1 compression
na, i just started it once each time and let it run for a few sec - am i supposed to rev it or somthin?
how am i supposed to test it with no fuel going to the engine?
i dont know much..
Modified by fuctup at 11:18 PM 3/2/2004
i dont know much..
holly **** dude, u really dont know what the freak u're doin!!!!
1. On your passenger side in the engine bay, take out the ECU fuse.
2. Take out 1 spark plug/wire.
3. Get your compression tool in the sparkplug hole.
4. Crank your engine 4 times and their's your compression.
i took out all my plugs and wires but whatever way both work better then the fucked up way you where trying it did you not look up how to do a compression test my tester had directions come with it even
Ok
Here we go:
Remove fuel injector or fuel fuse....
remove spark plugs
insert tester
have someone try starting it at WOT and let it crank 3-4 times
Repeat for cylinders 2-4
Mind you this is a crude write up but if you search and read your directions thats what it should say....I would guess compression tests should be in the 180's-200's psi (based off of what I have read on here
Here we go:Remove fuel injector or fuel fuse....
remove spark plugs
insert tester
. Mind you this is a crude write up but if you search and read your directions thats what it should say....I would guess compression tests should be in the 180's-200's psi (based off of what I have read on here
actually i just found a compression tester in my garage behind some **** and figure i'd test it seeing as how i have half my junkyard turbo setup.. i pretty much do everything by books and what i read on here and there rest is drunken guessing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D21X »</TD></TR><TR><TD CLASS="quote">holly **** dude, u really dont know what the freak u're doin!!!!
severe97
16
Nov 6, 2007 05:34 PM
logictron2000
Jun 16, 2003 07:17 PM
hybridcrx
Jun 26, 2002 07:11 PM
