necessary to set tdc on oil and water pump??
Water pump, no. I can't remember if it has a mark on the gear.... If it does, then line it up with what your helms tells you to do.
Front balancer shaft oil pump - I always align them to the indent on the block. Look through your helms and you'll see what to line them up in reference to.
then you are fucked. Tell me your email addy and I'll help you out.
By the way, why in the **** are you trying to assemble a motor without a manual for? Are you going to german spec for torque values?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">then you are fucked. Tell me your email addy and I'll help you out.
By the way, why in the **** are you trying to assemble a motor without a manual for? Are you going to german spec for torque values?</TD></TR></TABLE>
my manual is honda tech, haha
