code 41..... no vtec ??
Old Mar 2, 2004 | 12:21 PM
BlackCRX's Avatar
Default code 41..... no vtec ?? please help trouble shoot
just finished a y8 swap into my crx and now im getting code 41
i did a search and tried to see if i wired it wrong or if i have a dead o2 sensor
currently running a 4 wire o2 sensor
white = signal, green = heater sensor, black/yellow = ground, black/white = power
all the search threads that i read said to ohm out the heater wire to ground and it should range from 15-40ohms
i ohmed mine out and got 540 with the motor off
was i suppose to ohm the heater to ground when the car is on ?? or off ??
also if i get code 41 does vtec not kick in ??
i took it for a boot a few times and i didnt hear or feel a vtec change over
i dont have any LED's either to test the vtec output of 12V's
can some one pelase help
Old Mar 2, 2004 | 03:02 PM
BlackCRX's Avatar
anyone ??
vtec25
May 11, 2011 09:13 AM
daredeezy619
12
Mar 6, 2008 05:41 AM
blindoboy87
Jun 24, 2006 02:01 PM
UNDER PRESSURE
Jan 8, 2005 05:05 PM
2trix
May 28, 2003 12:10 PM
