obd I into II chassis
Old Mar 2, 2004 | 11:23 AM
advanracing62's Avatar
Default obd I into II chassis
I'm stumped on my other question here, so I'll ask this.
Installing an OBDI motor and harness into an OBDII chassis would require OBDII dist. and engine harness in order to run correct?
Old Mar 2, 2004 | 11:58 AM
stevieteg's Avatar
Default Re: obd I into II chassis (advanracing62)
my obd1 runs fine in my obd2 chassis. The motor plugs right in. obd1 dist. works fine too. The only thing you need is a jumper harness to use the obd1 ecu.
Old Mar 2, 2004 | 12:17 PM
vtecb20coupe's Avatar
B A N N E D
if you've already got the obd1 engine harness, all you'll need now is an obd1 ecu and the obd2 to 1 jumper.
Old Mar 2, 2004 | 01:12 PM
Default Re: obd I into II chassis (vtecb20coupe)
would it start if I was using the OBD II haness and computer?
what I mean is, I'm not getting spark or fuel- my thinking is that because I'm using the OBD II ecm and harness (interior) that I'm not getting what I need... does that make sense?
Old Mar 2, 2004 | 02:02 PM
eh?
Old Mar 5, 2004 | 10:40 AM
I got my OBD II to I conversion harness today- Still no spark/fuel- Maybe the dist. is bad? would that cause the car to not get power to half the main relay?
Old Mar 5, 2004 | 10:50 AM
mmuller's Avatar
Mad Scientist
have you tested to see if you get power to the main relay?
obd1 dizzy works just fine with obd2 ecu, but now you have a conversion harness....
and if that's not it check ignitor
Old Mar 5, 2004 | 10:57 AM
Default Re: obd I into II chassis (mmuller)
we're only getting power to half of the main relay-
Max500
Jun 14, 2009 02:53 PM
vtecftw
Aug 11, 2007 11:15 AM
NsX_CrX
Nov 19, 2005 12:49 PM
Hites
Nov 25, 2003 04:41 AM
TURBOED-TEG
Sep 14, 2002 02:28 PM
