headunit ?
Old Mar 2, 2004 | 09:28 AM
Lil Corb's Avatar
Default headunit ?
I just came back from Merchants and they disconnected my battery which deleted my headunit code. I popped open the panel by the glove compartment and looked at the side of the headunit and got a bunch of numbers but they are wrong. Where is the serial number located at on the headunit?
thanks
Old Mar 2, 2004 | 09:37 AM
95civicracer's Avatar
it will be on the back if i remember correctly
Old Mar 2, 2004 | 09:55 AM
Lil Corb's Avatar
Default Re: (95civicracer)
I tried to take out headunit and with no luck. It's for a 2000 si, if any1 has step by step instructions would gladly appreciate it.
thanks
Old Mar 2, 2004 | 10:01 AM
Lil Corb's Avatar
Default Re: (Lil Corb)
any1
Old Mar 2, 2004 | 10:32 AM
eskoobie's Avatar
try
http://www.installdr.com
Old Mar 2, 2004 | 10:38 AM
tominos's Avatar
you're trying to take out the si headunit to look for the serial on the back?
1. take off panel where the cig. lighter is atached to
but in order to do that, you have to take off the panel right under the steering column, and lower the glovebox so you can get to the screws for that panel. after that, you can reach to the back of the radio, don't know if it's bolted in though, just look under there... hoped that helped some.
Old Mar 2, 2004 | 11:40 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (tominos)
Much easier to put an aftermarket headunit in at this point .
Old Mar 2, 2004 | 11:57 AM
Lil Corb's Avatar
thanks guys for everything
raphael
Audio / Security / Video
Nov 6, 2011 02:40 AM
c4virus
Apr 24, 2007 05:14 PM
WhiteOnRice
Mar 19, 2007 07:06 PM
joey funk
Honda Civic (2001 - 2005)
Jan 22, 2007 06:37 PM
fi76sh
Feb 19, 2006 08:58 PM
