Alternator replacement
Old Mar 2, 2004 | 06:21 AM
bobubank's Avatar
Default Alternator replacement
I need to replace the alternator on my 1989 Honda Civic. The two bolts are removed, but I can't take out the alternator. If I want to take it out from the top, it looks like I need to remove the master brake cylinder. If I want to remove from the bottom, then I need to knock out the axle to provide clearance for the alternator. Does anyone have any suggestions?
Thanks
Old Mar 2, 2004 | 06:39 AM
leeit2me's Avatar
Default Re: Alternator replacement (bobubank)
If I am correct, I think you have to take off the bracket off that mounts the alternator. There is two or three bolts that bolts to the engine block. There is no other way to pull it out with out removing that bracket.
Old Mar 2, 2004 | 07:27 AM
bobubank's Avatar
Default Re: Alternator replacement (leeit2me)
Thanks, I'll take a look.
norcalB18
Jul 3, 2009 02:31 PM
MR_Se7en
Mar 25, 2008 10:04 AM
gp70hs
Jul 13, 2007 07:12 PM
91 civic
Apr 22, 2003 03:38 PM
Street Racer
Mar 15, 2002 11:43 AM
