Billowing white smoke
Old Mar 2, 2004 | 05:54 AM
dstahl01's Avatar
Default Billowing white smoke
Hello all. I have recently performed major repairs and upon initial startup of the engine it is billowing white smoke from the exhaust. I replaced my timing belt, water pump, head gasket, intake manifold gasket, exhaust manifold gasket, and reworked the valves, seats and valve stem guides are new. All bolts are torqued to required specs. Does anyone have any suggestions?
Old Mar 2, 2004 | 06:00 AM
Runnerdown's Avatar
Default Re: Billowing white smoke (dstahl01)
Was the head checked for straightness or cracks? Had it been badly overheated?
Old Mar 2, 2004 | 06:31 AM
AgentJam's Avatar
Default Re: Billowing white smoke (Runnerdown)
Definitely a head gasket problem...
As posted above...
1) head/block checked for straightness?
2) was the head/block clear of all gasket material?
3) sealer/copper spray used?
Vince
Old Mar 2, 2004 | 06:40 AM
highhopes's Avatar
Default Re: Billowing white smoke (AgentJam)
did you happen to change the oil after you were done with the repair? If not, either water or coolant could still be in the oil supply ---> white smoke
check your oil, see if there's water in it
Old Mar 2, 2004 | 06:58 AM
Filthy Focker!'s Avatar
Wait a minute here... DOn't need to jump to conclusions here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dstahl01 &raquo;</TD></TR><TR><TD CLASS="quote">I have recently performed major repairs and upon initial startup of the engine it is billowing white smoke from the exhaust.</TD></TR></TABLE>
Does it still do it, or was it just at initial start up?
fs
Old Mar 2, 2004 | 07:35 AM
dstahl01's Avatar
Default Re: Billowing white smoke (filthy_shovel)
I had it running for about 10 minutes. The strangest thing is that the car hasn't even warmed up enough for the thermostat to open and circulate the coolant. The radiator level has not gone down. How long should I let it run before I conclude that there is a definate problem?
Old Mar 2, 2004 | 07:37 AM
Jays91DXhatch's Avatar
I did an engine swap this past weekend. On start up and most of my drive into work this morning (50km, first ride with the car) there was white smoke at idle when I was stopped at a light. Not white smoke like there's coolant in the engine, I know what that looks like, it's THICK white smoke. This was just white smoke.
When I got to work, I parked the car and went out and it wasn't smoking anymore at idle..
It could be moisture got in etc when you did the rebuild...?? I dunno.
Old Mar 2, 2004 | 07:39 AM
dstahl01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">Was the head checked for straightness or cracks? Had it been badly overheated?</TD></TR></TABLE>
It had not been overheated at all. When I did the valve job, I replaced the head gasket as a preventative measure.
Old Mar 2, 2004 | 07:40 AM
dstahl01's Avatar
Default Re: Billowing white smoke (Jays91DXhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jays91DXhatch &raquo;</TD></TR><TR><TD CLASS="quote">I did an engine swap this past weekend. On start up and most of my drive into work this morning (50km, first ride with the car) there was white smoke at idle when I was stopped at a light.
Did the level of smoke increase at higher rpms?
Old Mar 2, 2004 | 07:59 AM
ComputerJLT's Avatar
does the smoke smell like oil or coolant?
Old Mar 2, 2004 | 08:07 AM
Did the level of smoke increase at higher rpms?</TD></TR></TABLE>
No, when I was driving I couldn't tell there was smoke.
I remember following my buddy when his head gasket was blown.......The whole neighbourhood was in white smoke... LOL
It's hard for me to tell the smell, since I put on new exhaust, and fluids spilt all over throughout the swap, so it smells from all that.
Old Mar 2, 2004 | 08:10 AM
Higher rpms mean when you rev it up... The car does not have to be moving...
Ride it for a couple of days and see if it clears up...
fs
Old Mar 2, 2004 | 08:11 AM
dstahl01's Avatar
Default Re: (ComputerJLT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComputerJLT &raquo;</TD></TR><TR><TD CLASS="quote">does the smoke smell like oil or coolant?
It doesn't have a smell to speak of....It is white as a sheet of paper.
It is a manual transmission....----v
Modified by dstahl01 at 3:00 PM 3/2/2004
Old Mar 2, 2004 | 08:27 AM
Default Re: (dstahl01)
Hey what kind of trnny do you have. Auto or trans.
If auto, may be transmission fluid may be entering the intake manifold through vacuum connections. check it out..
fs
mannydhanju
Feb 21, 2009 09:33 PM
SleepyHatchZ6
Oct 28, 2008 07:54 PM
Lokisdope
Oct 6, 2007 06:31 PM
k7q
12
Oct 8, 2006 08:12 PM
B18C-Hatch
Sep 6, 2006 10:54 AM
