MY car got idling problem (need some advise)
Old Mar 2, 2004 | 02:24 AM
XxWhiTEeg6xx's Avatar
Default MY car got idling problem and also keep dying out (need some advise)
i have a eg with a usdm b18c5 swap in it. i check my compression and here was the result 190-180-120-190. here the problem. when i start up my car when it completely cold, it's idle at 800 and seem like the motor is choking.when it have a 2min warm up it,the ilde started to rise to 1300rpm. so i guess the motor kool now. Here another thing. when i drive around and blast v-tec just one time, my car all a sudden die out while i'm moving so i gotta put it in gear and pop start it. sometime outta no way when i make complete stop, the rpm just drop to 400 and it die out.when i start it up, it happen again.
i try to fix the problem but it still the same. i puts new spark plug and spark plug wire. clean out my idle control valve. put a gsr fuel pump, clean out my throttle body. used some the chevon gas cleaner which kinda help alittle.but still didn't solve the problem
i dunno i hope you guy can solve my problem
Shojin
Dec 24, 2017 02:55 PM
_Tim
Oct 11, 2008 12:00 PM
Thrillahbeeh
Feb 23, 2008 05:57 PM
Vtec_Dude
Feb 17, 2008 06:38 PM
mark2583
Jan 9, 2008 03:13 PM
