Garrett T3 ~"45" trim
Old Mar 1, 2004 | 09:14 PM
Tushner's Avatar
Default Garrett T3 ~"45" trim
I've looked at compressor maps but I can't calculate the CFM my engine would flow: D16A1 (built). I've been running this turbo at 8psi for a year now on the old block so I have it in my possesion - I'm not shopping for this "45" trim turbo; just curious to see what it will support.
Does anyone know either the CFM to use for my engine or an idea as to whether this turbo will support 250-75whp?
Thanks in advance...
Old Mar 1, 2004 | 09:16 PM
b16ahybrid's Avatar
Default Re: Garrett T3 ~"45" trim (redteg_87)
I think that your probably pushing it if your wanting 275whp out of it. I'd say more like 220 hp or so wuld be the limit. Icould be wrong, this is just my oppinion no actuall facts.
Old Mar 1, 2004 | 09:17 PM
Tushner's Avatar
Default Re: Garrett T3 ~"45" trim (b16ahybrid)
Thanks for the reply. I suppose the only real goal for this turbo is the 250whp, anyways.
What turbo are you running on the B?
Old Mar 1, 2004 | 09:19 PM
TravSi's Avatar
if you want to support those numbers I would say t3 60 or super 60...i run the 60 trim and im roughly around 250ish on 10psi...Works very well on the D series
Old Mar 1, 2004 | 09:20 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redteg_87 &raquo;</TD></TR><TR><TD CLASS="quote">
What turbo are you running on the B?</TD></TR></TABLE>
T3T4OE .57 trim .63 A/R
Old Mar 1, 2004 | 09:23 PM
Tushner's Avatar
Default Re: Garrett T3 ~"45" trim (TravSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravSi &raquo;</TD></TR><TR><TD CLASS="quote">if you want to support those numbers I would say t3 60 or super 60...i run the 60 trim and im roughly around 250ish on 10psi...Works very well on the D series </TD></TR></TABLE>
Thanks for the reply. I'll start searching for these. The T3 .60 was off of the Thunderbird with the manual tranny, right? The auto had a .42 or so exhaust?
You wouldn't happen to know of any for sale, would you?
Tushner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
T3T4OE .57 trim .63 A/R</TD></TR></TABLE>
Good choice, I have a friend on a B18 running 300whp on that turbo.
Old Mar 1, 2004 | 09:26 PM
b16ahybrid's Avatar
B18c,b,a?
How much boost did it take?
Old Mar 1, 2004 | 09:29 PM
Tushner's Avatar
Almost certain it was a B18b. Not sure on the psi but he put down 298whp on a Mustang dyno with stock bottom end.
He just got the block back from a little buildup and will be shooting for the big 400whp this Spring. If I remember I'll tell you what turbo he's going to run for that (or if the current T3/T4 breathes up there).
TravSi's Avatar
Well you can buy them from any turbo dealer its an off the shelf turbo...it can come with .48, .63 or .82 turbine housing....I run the 60 trim with a .48 turbine...spools at like 3300 and full boost by like 4000ish, im gonna upgrade to the .63 housing this summer when i get some more parts to go for the 300 hp goal, but im def. happy with the power im making and the car pulls so strong to redline and beyond, when i shift I still feel there is more power left to be had....
http://www.cheapturbo.com
http://www.slowboyracing.com
http://www.turbonetics.com
and any other garrett turbo dealer can get them.....
Old Mar 1, 2004 | 09:31 PM
Tushner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravSi &raquo;</TD></TR><TR><TD CLASS="quote">Well you can buy them from any turbo dealer its an off the shelf turbo...it can come with .48, .63 or .82 turbine housing....I run the 60 trim with a .48 turbine...spools at like 3300 and full boost by like 4000ish, im gonna upgrade to the .63 housing this summer when i get some more parts to go for the 300 hp goal, but im def. happy with the power im making and the car pulls so strong to redline and beyond, when i shift I still feel there is more power left to be had....
and any other garrett turbo dealer can get them.....</TD></TR></TABLE>
Thank you very much, sir. Very helpful.
Old Mar 2, 2004 | 09:25 AM
Tushner's Avatar
Bump for the day.
Old Mar 2, 2004 | 09:43 AM
Bailhatch's Avatar
I run a 50 trim t3 with .63 turbine and .42 comp. starts spooling at about 3000 8psi by 4000.
Old Mar 2, 2004 | 11:16 AM
Tushner's Avatar
Default Re: Garrett T3 ~"45" trim (Bailhatch)
This one spools a little quicker. It puts out about 8psi by 3500rpm.
Any idea as to what these top out at?
Old Mar 2, 2004 | 01:28 PM
TravSi's Avatar
it will run out of air in the higher rpms.....wont be as efficent up high, should make some good low end torque numbers though
Old Mar 2, 2004 | 04:44 PM
Johnyquest's Avatar
Here's a link to the compressor map.
http://www.turbocalculator.com...5.jpg
It flows its maximum at a boost pressure of 19.11 psi, if I did my math right (2.3pr)...
So what i'm saying is, if you want to know what the most that turbo can do is, you will need to turn it up to 20psi, for that's the boost level where it gives 'all it's got.'
With a good intercooler, you might be able to squeeze a bit more out of it, but that's getting towards it's limits. 65% efficiency is still better than a supercharger, so turn it up and get on the dyno
I personally (think) I have a 50 trim, and i'm about to do the same once uberdata is up and running for me. My 50 trim can move a bit more at the same (maximum) pressure (~20psi).
Give it a shot!
Good luck.
Old Mar 2, 2004 | 05:04 PM
Wide Open Throttle's Avatar
You wouldn't happen to know of any for sale, would you? </TD></TR></TABLE>
the thinderbirds came with a .48 a/r exhaust side and .60 a/r compressor, with a 60 trim wheel. these can be had on ebay from time to time (i got mine refurbished for $300, with a wastegate). t3's with a .48 exhaust and .42 compressor are on ebay ALL the time. i think these also came on the thunderbird (maybe this is the automatic turbo?)
Old Mar 3, 2004 | 08:59 AM
Tushner's Avatar
Default Re: Garrett T3 ~"45" trim (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">Here's a link to the compressor map.
http://www.turbocalculator.com...5.jpg</TD></TR></TABLE>
I've looked at the maps but I can't figure out the x-axis because I don't know what CFM to use for my engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">It flows its maximum at a boost pressure of 19.11 psi, if I did my math right (2.3pr)...
Give it a shot!
Good luck. </TD></TR></TABLE>
I'll just see what the thing can do on the dyno when the new block is in. It should be interesting, if nothing else!
Old Mar 3, 2004 | 09:00 AM
Tushner's Avatar
Default Re: Garrett T3 ~"45" trim (Wide Open Throttle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wide Open Throttle &raquo;</TD></TR><TR><TD CLASS="quote">
t3's with a .48 exhaust and .42 compressor are on ebay ALL the time. i think these also came on the thunderbird (maybe this is the automatic turbo?)</TD></TR></TABLE>
I think those are usually Volvo or Saab turbos.
boostdummy
Jan 21, 2006 09:18 PM
hondahatch741
May 30, 2005 12:36 PM
seamoss
Apr 8, 2005 11:49 AM
reaction360
Jul 2, 2004 01:31 AM
M.A.R.C.
Jun 10, 2002 03:23 PM
