B18C5 bottom end with wiseco 13.1 compression pistons
Old Mar 1, 2004 | 06:54 PM
K20crx's Avatar
Default B18C5 bottom end with wiseco 13.1 compression pistons
Will individual throttle bodies on a portflow gsr head with m24x cams be streetable?
Old Mar 1, 2004 | 07:47 PM
TEAMGENDAI's Avatar
Default Re: B18C5 bottom end with wiseco 13.1 compression pistons (JDMmA707)
Depends on you.
I say anything is streetable if you are down enough to drive it.
Good luck!!
Bubba
Trackmasters
Horizon Motorsports
Old Mar 1, 2004 | 08:37 PM
JDM2ndGen's Avatar
Default Re: B18C5 bottom end with wiseco 13.1 compression pistons (TEAMGENDAI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEAMGENDAI &raquo;</TD></TR><TR><TD CLASS="quote">Depends on you.
Good luck!!
Bubba
Trackmasters
Horizon Motorsports</TD></TR></TABLE>i like your thinking ...and thats how i look at it ..also depends on the tuning of the motor ...
Modified by JDM2ndGen at 5:58 AM 3/2/2004
Old Mar 1, 2004 | 08:49 PM
T.J.'s Avatar
dpends on how good of tunning, and what you use to tune it with
Old Mar 1, 2004 | 09:15 PM
infamousR13's Avatar
It would all come down to tuning and what gas you are using, but it would be one bad *** street car.
Old Mar 1, 2004 | 09:58 PM
Stdsnb16's Avatar
I hope your running a good set of aftermarket injectors! You're going to have to tune it no matter what. Hopefully the idle won't be too bad.
Stdsnb16
Old Apr 5, 2004 | 09:06 PM
Plan B's Avatar
Default Re: B18C5 bottom end with wiseco 13.1 compression pistons (K20crx)
You can drive it on the street, but I wouldn't be delivering newspapers or going on trips more than 50 miles on that.
Old Apr 5, 2004 | 09:32 PM
GetawayInMoscow's Avatar
Default Re: B18C5 bottom end with wiseco 13.1 compression pistons (Plan B)
Arent most ITB setups w/o air filters though?
Old Apr 5, 2004 | 09:47 PM
Eddiebx's Avatar
you can always get little air horn socks for them
Old Apr 6, 2004 | 02:53 PM
allm0t0rsir's Avatar
Good luck!!
Bubba
Trackmasters
cincyb20ek
Jul 12, 2010 06:31 PM
ge_itr
Sep 4, 2007 12:09 PM
_SHEP_
Honda S2000
15
Aug 27, 2007 07:00 PM
z6
28
Nov 4, 2005 08:40 AM
TurboSam
Oct 15, 2003 06:46 AM
