ECU chip burning question.
My friend has everything to burn chips with boost options. Just wondering if i can use an old GUDE computer i have(which is already socketed and chipped) and burn over the GUDE program? If not, the ECU and socket should be good right, if anything i might just need a new chip?
That's the erase port (normally why it's covered), it allows you to erase the EPROM under a certain frequency of light which differs from an EEPROM as it can be written over electronically... As for your question, it will work but with a new chip... Unless you have a light source capable of erasing your current chip... New 27256 ROMs (or the like) are only like $5.00 or less tho... Hope this helps
Go for the 29c256 chips from Atmel.. You can get them from http://www.moates.net or digikey..
