Window out of track
Old Mar 1, 2004 | 02:43 PM
Bamex's Avatar
Default Window out of track
Hello all,
minor prob i cant seem to get my driver side window all the way up! i took off the door panels and it is out on both rubber runners! the motor works fine but it wont go all the way up! i cant seem to squeeze in back into the runners! any ideas its a 96 ex power windows! mayb im just a retard but hey!
Old Mar 1, 2004 | 02:46 PM
flipp117's Avatar
Default Re: Window out of track (Bamex)
that happened to me a few times im not sure if its the same prob tho.. basically the bolt holding the window got loose. im a noob and the terms im using mite be wrong but u may want to take out the 6'' speaker and behind it you will find where the track hooks up to the window. try realligning it and tightening the bolts... hope that helps
Old Mar 1, 2004 | 02:49 PM
92civeg's Avatar
Default Re: Window out of track (flipp117)
i would unbolt the glass get it back on track and then bolt it back up
Old Mar 1, 2004 | 04:57 PM
Bamex's Avatar
Default Re: Window out of track (92civeg)
ok fixed the track problem but now the window is kinda sluggish! motor kinda goes and then slows down going up and down! bad motor?
Old Mar 1, 2004 | 05:15 PM
jspexae102's Avatar
That happened to me before.. yea its best to take the track off and put it back on.. it worked good as new after that..
Old Mar 5, 2004 | 09:44 AM
oeklm's Avatar
Default Re: Window out of track (jspexae102)
use sum silicone spray in the rubber tracks or sum white lithium grease.. my rubber track unforunately got all messed up because my cousin forced it up all the way off the rubber track. I just ordered a new one but dont know if it is hard to change. Anyone done this before?
khronicboy420
Dec 26, 2008 08:19 PM
whatan00b
Aug 19, 2007 01:04 PM
hotdoggies
Feb 19, 2006 10:03 AM
btole
Sep 13, 2004 08:01 PM
mrlegoman
Aug 8, 2002 12:40 PM
