custom reciever install in 99 civic
Old Mar 1, 2004 | 12:39 PM
fresh99si's Avatar
Default custom reciever install in 99 civic
i took my reciever out of its original pocket and i want to move it to the lower pocket by the shifter....is there a kit or an easy way to do this???
Old Mar 1, 2004 | 12:42 PM
screech's Avatar
Default Re: custom reciever install in 99 civic (fresh99si)
it should fit with no kit or modifaction it should bolt right into place. mine did and i have a pioneer 550 in a 98 civic
Old Mar 1, 2004 | 12:46 PM
fresh99si's Avatar
how would i bolt in a aftermarket cd player? and because it is a 1 din cd player, i would still have to have a plate around it to cover the area surrounding the cd player, right?
Old Mar 1, 2004 | 02:56 PM
screech's Avatar
Default Re: (fresh99si)
the aftermarket cd player should have come with some screws when you take out the cubby you should see a bracket down there your cd player will bolt in the same way the cubby does but involves taking all that **** down there out. the cup holders and center console and climate control. you can just get the block off plate to take care of the hole up top.
Old Mar 1, 2004 | 03:03 PM
Built Beast's Avatar
you have to get the 96-98 civic pocket with the flip-up cupholders, because you have a 99 civic you have the pocket with the two different size cupholders and a big pocket. Just get the other style pocket and you will be set.
Old Mar 1, 2004 | 03:05 PM
137's Avatar
137
Default Re: custom reciever install in 99 civic (R33CIVIC)
go to honda... they have a oem kit.
Old Mar 1, 2004 | 03:33 PM
fresh99si's Avatar
honda has an oem aftermarket reciever mount kit that i can put in the pocket???thanks man, im goin to honda tommorrow
sevenfc
Oct 7, 2009 02:23 PM
SiKid86
May 15, 2005 02:16 PM
EnriqueDovis
13
Sep 26, 2004 04:01 PM
xvietxkhmerxboix
Audio / Security / Video
Mar 5, 2003 12:34 PM
