Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
H&R extended wheel studs - Yay or Nay?
Old Mar 1, 2004 | 10:30 AM
thk's Avatar
thk
Members Only
Default H&R extended wheel studs - Yay or Nay?
If it's not one thing, it's another.
Besides the little clutch/flywheel/transmission problem which surfaced in VIR, it seems that my wheel bearings are going south. Since I've opted to replace them now instead of later, it gives me an opportunity to put in extended wheel studs. It's a good idea since I am running a 5mm spacer up front and I'm at the safe limit right now in the amount of turns on the lug nut.
Now, I have a set of extended lugs that came with the H&R spacer kit. Should I just go ahead and use those or order up ARP/TL extended studs? I'm leaning towards the H&R/TL studs because I'm "assuming" that I won't need to get open ended lug nuts (yet). The ARPs seem quite long and might require the open ended lug nuts.
Anyone have experience with H&R wheel studs? Good? Bad?
Old Mar 1, 2004 | 12:07 PM
travis's Avatar
Default Re: H&R extended wheel studs - Yay or Nay? (thk)
Have you read this?
https://honda-tech.com/zerothread?id=244036
Old Mar 1, 2004 | 12:19 PM
thk's Avatar
thk
Members Only
Default Re: H&R extended wheel studs - Yay or Nay? (travis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis &raquo;</TD></TR><TR><TD CLASS="quote">Have you read this?
https://honda-tech.com/zerothread?id=244036</TD></TR></TABLE>
Doh. Thanks for the link.
I tried "stud(s)" and "extended studs" but didn't try wheel studs.
I'll need to double check when I get home tonight but IIRC, the ones I received looked a lot like the OE knurl than the ones pictured in that thread. If not, I'll have Yack order the OE/TL ones. Thanks.
Old Mar 1, 2004 | 12:40 PM
.RJ's Avatar
.RJ
The ARP studs will make it easier to get the lugs on... there's a non-threaded portion (forget the term) at the end of the stud.
Old Mar 1, 2004 | 12:46 PM
thk's Avatar
thk
Members Only
Default Re: H&R extended wheel studs - Yay or Nay? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">The ARP studs will make it easier to get the lugs on... there's a non-threaded portion (forget the term) at the end of the stud.</TD></TR></TABLE>
Yeah. It looks like the ends are tapered but I'm curious if ... waitaminute. Lemme PM Willard. He has ARP studs. I can ask him to put on my spacers and wheels on his car to see if my current lug nuts fit the ARP studs. Bingo.
But I still might try out the H&Rs. Need to stop the hemorrhaging a bit by using what I have instead of ordering more parts.
Old Mar 1, 2004 | 01:04 PM
Willard's Avatar
my ARP's have threads all the way.
Toy Civic
Jun 6, 2008 01:06 PM
Midori Green
15
Jan 1, 2008 10:39 PM
Okininam
Jun 5, 2006 12:46 AM
ActiveAero
Dec 4, 2004 01:32 PM
EKFerioHawaii
Oct 2, 2002 02:08 PM
