Quick Battery Question.
My car has started up since i got it. The ast time i went out to start my car it wouldnt start though. The starter turned fine but the engine wasnt turning. I bumped it and figured i just left something on. I got home and checked everything and made sure everything was off. Then the next morning the car wouldnt start again and i had to bump it again. I checked the terminals and cleaned them up a bit but that didnt help out. When i try to start it now i can smell sulfur from the battery and i bubbles a bit. Im pretty sure its the battery but can it be something else. The battery is fairly new. Thanks in advance
Your altenator might be overcharging the battery. Put a voltmeter across the battery with the car running and it should not exceed 13.5 volts. Better than that pick up a $3.00 dollar hydrometer and check each cell. You should have no more than 25 points between each cells readings Good Luck
speedracer33
May 2, 2005 08:57 AM
liljohnson
Jul 30, 2004 10:27 PM
