Anyone fixed stripped block threads from wrong headbolt? helicoil?
Old Mar 1, 2004 | 06:17 AM
6ghatch's Avatar
Default Anyone fixed stripped block threads from wrong headbolt? helicoil?
I found a good deal on a GSR shortblock but the owner put the wrong headbolts in the head and stripped the threads. If I took the block to a machine shop could they put in a helicoil and would this be strong enough for N/A application?
EDIT: Also, for a poor mans ITR setup, I'll be using my 99 B16a head. What headgasket should I use b16a or b18c? how much compression will I get back using a 1 or 2 layer headgasket? GSR oil pump and timing belt?
Modified by 6ghatch at 10:55 AM 3/1/2004
Old Mar 1, 2004 | 10:12 AM
blwnb16a's Avatar
Default Re: Anyone fixed stripped block threads from wrong headbolt? helicoil? (6ghatch)
timecerts the manchine shop will know what they are
b16 and b18 gaskets are the same
Old Mar 1, 2004 | 10:44 AM
TECH43 RACING INC.'s Avatar
Default Re: Anyone fixed stripped block threads from wrong headbolt? helicoil? (blwnb16a)
RS 310-328-5514 ask for john.
MR. BAR
Jul 25, 2005 07:33 AM
MR. BAR
Jul 20, 2005 09:58 AM
jdmbuilt
Jun 18, 2003 12:05 PM
RAWB
Feb 21, 2003 12:24 PM
