Someone tell me how much hp you can pull out of a crv/vtec 2.0
I was wanting to know how much boost I can pull out of a vtec head and crv block. has anyone done it and how much HP you pull out of it.
B20's suck. Paperthin stock sleeves lead to explosions.
They can't even handle high compression N/A setups. Sleeving them is another story... in which case I'd use an LS/GSR/B16 block regardless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin »</TD></TR><TR><TD CLASS="quote">was jason using the b20 crank too though?</TD></TR></TABLE>
B20 crank should be the same as b18 crank. Just different bore size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin »</TD></TR><TR><TD CLASS="quote">lemme bust out the ht calculator
b20 block
vtec head
boost
calculating...
= cracked sleeves and spun bearings
</TD></TR></TABLE> funny shyt
b20 block
vtec head
boost
calculating...
b20 block
vtec head
boost
calculating...
stock, of course.
b20 block
vtec head
boost
calculating...
stock, of course.
