starting problem
when I turn my key to start the car, the starter turns for about 1/8 of a sec, stop, and if I keep on holding, the starter turns again and the engine start. I don't think it is the starter because it is new. Could it be a relay problem? I'm guessing the relay doesn't make good contacts thus not providing enough amps to the starter. I have no idea how the is ignition wired so it is just a guess. What happen when the key is turn to start the starter? What is going on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel »</TD></TR><TR><TD CLASS="quote">How old is your battery... Look at the obvious first...
Test it out...
fs</TD></TR></TABLE>
also, make sure all ur plug wires are on securly along w/ the battery terminals...if it was praticulary cold in the night (anytime theres a big temp drop during the night) the car will start alot rougher....its normal...(sometimes takes a few tries to start in sub zero
i hate MI)
Test it out...
i hate MI)
junya16
Feb 26, 2003 08:31 AM
