starting problem
Old Feb 29, 2004 | 07:06 PM
david90's Avatar
Default starting problem
when I turn my key to start the car, the starter turns for about 1/8 of a sec, stop, and if I keep on holding, the starter turns again and the engine start. I don't think it is the starter because it is new. Could it be a relay problem? I'm guessing the relay doesn't make good contacts thus not providing enough amps to the starter. I have no idea how the is ignition wired so it is just a guess. What happen when the key is turn to start the starter? What is going on?
Old Mar 1, 2004 | 09:20 AM
Filthy Focker!'s Avatar
Default Re: starting problem (david90)
How old is your battery... Look at the obvious first...
Test it out...
fs
Old Mar 1, 2004 | 09:36 AM
fw190bvi's Avatar
Default Re: starting problem (filthy_shovel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">How old is your battery... Look at the obvious first...
Test it out...
fs</TD></TR></TABLE>
also, make sure all ur plug wires are on securly along w/ the battery terminals...if it was praticulary cold in the night (anytime theres a big temp drop during the night) the car will start alot rougher....its normal...(sometimes takes a few tries to start in sub zero i hate MI)
FSS13foxtrot
Apr 1, 2008 08:05 PM
uneek4dr
Honda Civic (2001 - 2005)
Dec 2, 2007 09:12 AM
5lugSlug
Jul 13, 2005 06:41 AM
mingchi69
Jul 14, 2003 06:14 PM
junya16
Feb 26, 2003 08:31 AM
