Screeching sound from motor at idle (vid inside)
Old Feb 29, 2004 | 04:54 PM
1bar's Avatar
Default Screeching sound from motor at idle (vid inside)
The motor is a b16a1, at idle when the car is warmed up, it makes a squelling sound. At first i thought it was the alternator but the sound isnt coming from there. More of the bottom of the block. I have a moive but its avi. and i dont know how to host it. If anyone knows how to host let me know.
jake
Old Feb 29, 2004 | 05:38 PM
onePOINTsix's Avatar
Default Re: Screeching sound from motor at idle (1bar)
not the alternater but maybe the alternater or power stearing (if you have it) belts
Old Feb 29, 2004 | 09:04 PM
1bar's Avatar
Default Re: Screeching sound from motor at idle (Sideout)
hmm i have no power steering ill check the belt tomorrow. can anyone host avi. movies??
Old Feb 29, 2004 | 09:42 PM
97Alex's Avatar
So it happens non stop whether your moving or not? ANy other conditions under which it happens?
Old Mar 1, 2004 | 02:43 PM
1bar's Avatar
Default Re: (97Alex)
more of when im stopped at idle. as soon as u rev its gone. sometimes it affects the idle speed it drops down very low and then goes up but never stalls.
Old Mar 1, 2004 | 04:04 PM
McDade's Avatar
Default Re: (1bar)
email it to me and i'll host the vid
Old Mar 1, 2004 | 08:30 PM
1bar's Avatar
Default Re: (McDade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by McDade &raquo;</TD></TR><TR><TD CLASS="quote">email it to me and i'll host the vid
just sent it thanks man
Old Mar 8, 2004 | 02:06 PM
97Alex's Avatar
you upload it to a site yet McDade?
Old Mar 8, 2004 | 04:11 PM
civboy115's Avatar
valve adjustment maybe? idk...
Old Mar 8, 2004 | 06:50 PM
McDade's Avatar
Default Re: (civboy115)
he said it was sent to me, yet i recived nothing
i tired im'ing but he did not respond
Old Mar 8, 2004 | 08:46 PM
jrcrx's Avatar
That screeching sound its probally metal touching metal, try using a better oil(syntec oil). If that does not work try adjusting your valves, its probally to tight, need to loosen the valve to cam gap!
Old Mar 8, 2004 | 09:18 PM
97Alex's Avatar
FELLAS, CALM DOWN! U cant just diagnose something without even hearing or seeing it. No, he doesnt need a rebuild, no he doesnt need a valve adjustment, EVERYBODY CALM DOWN and WAIT till he gets the video posted.
Common problem would be the belts. Could be too tight, too loose, or just glazed and makin some noice. Try putting some Accesory belt conditioner spray on the belts and see if that does anything.
Paprika
May 8, 2007 03:18 PM
budget
Mar 3, 2005 06:57 AM
Gump
12
Dec 5, 2003 02:11 PM
97hb
Jan 24, 2003 11:12 AM
