More power ; technical help plz..?!
i heard that if you , lets say, put a thicker head gasket on the engine, to lower the compression, it grows more power.. what do you guys think? if it does work, do i need to change/modify anything else? is it this simple?! lol im mixed up..
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nathan007 »</TD></TR><TR><TD CLASS="quote"> lol im mixed up.. </TD></TR></TABLE>
If that is the ONLY thing changed to the engine, you will most likely not gain power (possibly lose some.) But if you were to put a thinner headgasket and raise compression you might gain a slight amount.
You typically install a thicker headgasket to lower the compression ratio. This in turn will allow you to run a higher amount of boost. Simply installing a thicker HG will not make more power by itself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 »</TD></TR><TR><TD CLASS="quote">Simple answers
YOU WANT
Lower compression for turbo
Higher compression for all motor</TD></TR></TABLE>
Actually you DONT WANT lower compression for turbo....you NEED lower compression on turbo cars to fight detonation. Higher compression is always better no matter what; by having higher compression you improve engine's VE, thus making more power.
If not ask the pros.; running 10+ compression on top of 25+ pounds of boost
YOU WANT
