Speed Sensor and CEL ?
Old Feb 29, 2004 | 12:14 PM
Ralph Wiggum's Avatar
Default Speed Sensor and CEL ?
I've searched this topic before and I just found inconclusive information.
My problem is would not having a Electronic VSS and a Cable VSS throw an Check engine light. I have a B16 with a SiR gauge cluster and a Zdyne One pin PM6 ECU reprogramed to act like a PR3. My speedo stopped working before I ever did the motor swap and I don't have a Electronic VSS installed for the SiR cluster but I did attach the ECU TO CLUSTER speed signal wire. Also I want to know if anyone has a photo of a Cable VSS so I know what to look for when I go lookign for it around the tranny.
I'm curious to find out if that would ever put out a CHECK ENGINE LIGHT because I'm tryign to find out the cause of the CEL by starting with the small stuff first.
Any information would be greatly appreciated
Old Feb 29, 2004 | 02:30 PM
91civicDXdude's Avatar
yes. code 17 or code 19 is VSS
Old Feb 29, 2004 | 03:36 PM
Default Re: (91civicDXdude)
Would that CEL light come on right during start up or 5 min down the road? Because my CEL would come on about 5-10 min of driving depends if I'm on the freeway or regular roads
Thanks
Old Feb 29, 2004 | 03:52 PM
yep thats the symptoms i experienced
Old Feb 29, 2004 | 04:21 PM
Fobtions's Avatar
the engine light wont go on as long as u dont coast down from lets say 40+ mph in gear .
Old Feb 29, 2004 | 05:41 PM
crx_88_si's Avatar
Default Re: (Fobtions)
get an electric VSS from a 94+teg or 92+civic and bolt her up. Split the wire into two so 1 side goes to the cluster and 1 goes to the ecu.. done deal.
Old Mar 9, 2004 | 02:13 PM
dwchkypmp20's Avatar
Default Re: (crx_88_si)
thought the jspec b16s came with the electrical sensor? i have a JDM b16 in my rex and am having problems finding a speed sensor from a 92-93 teg...if im correct i need a cable sensor
ps same symtoms of my CEL....do you have VTEC?
GhostBoy99
Apr 28, 2019 01:17 PM
civicboy420
Aug 11, 2014 01:45 PM
Stangracer85
Dec 11, 2010 06:12 AM
sskracing
13
Aug 10, 2010 08:52 AM
GRPNHRD
Oct 1, 2006 04:54 PM
