Lower Ball Joint Problems...
Old Feb 29, 2004 | 11:58 AM
civicboisi's Avatar
Default Lower Ball Joint Problems...
Well...i kinda fucked up on my lower driver side ball joint...the castle nut spins freely with the stud...am i fucked? How am i supposed to get the nut off the stud now? Anyone have any idea? Need to know fast...
Thanks
Old Feb 29, 2004 | 02:52 PM
MightyMouseTech's Avatar
Default Re: Lower Ball Joint Problems... (civicboisi)
Create some friction between the stud and the lower control arm by grasping it with a large set of channel locks. Push the lower ball joint stud harder into the lower arm. Works every time.
Old Feb 29, 2004 | 03:10 PM
civicboisi's Avatar
Default Re: Lower Ball Joint Problems... (MightyMouseTech)
i figured it out...i had to jack that thing all the way in the air and have someone stand on the rotor to put weight on it.
Thanks for the help.
Old Jun 6, 2004 | 01:27 PM
PHiZ's Avatar
Well, what I did is I walked away for a while, and when I came back I brake-cleaner'ed both the threads on the ball joint, and the castle nut, cleaned them up real good, and it threaded on first try.
:doh: on me, it's a ball joint, it's SUPPOSED to spin, sigh.
-PHiZ
Modified by PHiZ at 8:04 PM 6/6/2004
Ef4doorwagon
Nov 21, 2014 03:47 PM
Kevins89notch
21
Nov 4, 2013 06:17 AM
91blackEF
Jan 4, 2009 01:31 PM
chibiko
Jun 6, 2007 08:45 PM
s-tech
Aug 6, 2005 10:30 AM
