Drag manifold question??????????????????????????????
Old Feb 29, 2004 | 10:43 AM
JusT a Cx's Avatar
Default Drag manifold question??????????????????????????????
i have the drag gen 3 manifold right now, and i was wondering what would be a better step up to run on my jdm b16???? and what wastegate ???
Old Feb 29, 2004 | 05:03 PM
JusT a Cx's Avatar
Default Re: Drag manifold question?????????????????????????????? (JusT a Cx)
bump
Old Feb 29, 2004 | 05:07 PM
g2turbo's Avatar
I also ran the drag 3 manifold and switched to a lovefab sst. As far as the wastegate, Tial makes a 38mm for about 225 which is a great upgrade over a deltagate.
Old Feb 29, 2004 | 05:10 PM
JusT a Cx's Avatar
Default Re: Drag manifold question?????????????????????????????? (g2turbo)
where can i get that manifold?? and how much is it for the b16
Old Feb 29, 2004 | 05:18 PM
JusT a Cx's Avatar
Default Re: Drag manifold question?????????????????????????????? (turbokitssuck)
my bad... when i posted that u must have already had yours posted..... soo i should just keep the drag manifold but upgrade my wastegate?? which would u recc by tial ?? 38mm but which bar ?
Old Mar 1, 2004 | 06:36 AM
JusT a Cx's Avatar
Default Re: (turbokitssuck)
bump
Old Mar 1, 2004 | 08:35 AM
g2turbo's Avatar
Default Re: (JusT a Cx)
what are your whp goals?
what wastegate do you have now?
http://www.lovefab.com
http://www.inlinepro.com
Remember when ordering a spring for the wastegate that you can always raise the boost , but you cant lower it unless springs are changed. So like the previous poster stated if you are going to run 8 psi then get the .55 bar spring.
The manifold you have now has made great numbers in the past so unless you are shooting for 400+ i wouldnt even bother changing it. A local shop made 518whp with a drag manifold 3ys ago but began running into boost creep issues due to wastgate placement.
Old Mar 1, 2004 | 08:38 AM
Carlito Brigante's Avatar
Default Re: (g2turbo)
i sent you a pm on the cast sidewinder...
Old Mar 1, 2004 | 08:39 AM
TeamCracka's Avatar
Another option for an alternate mani would be the MaxRev - it has a better wastegate placement, and the Drag's are known to crack and cause boost creep.
Old Mar 1, 2004 | 09:36 AM
tygsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">what are your whp goals?
The manifold you have now has made great numbers in the past so unless you are shooting for 400+ i wouldnt even bother changing it. A local shop made 518whp with a drag manifold 3ys ago but began running into boost creep issues due to wastgate placement.</TD></TR></TABLE>
GOod question. What are your whp goals? the drag manifold is good. I made 400whp on it..if your looking for more, and are on a budget the SFP manifold is dope, friend made 690whp on his
Old Mar 1, 2004 | 10:31 AM
JusT a Cx's Avatar
Default Re: (tygsr)
i plan on making 300whp with my set up @ 10psi of boost........ i jus heard the deltawastegate is garbage and that the drag manifold cracks .. soo iam looking into another one...... iam in the process of turbo'n now.... my set up consist of drag gen 3 turbo and wastegate.....spark racing intercooler, rc 440 injectors,hondata s100b,msd6aL ignition with blaster,arp headstuds,1mm headgasket(copper) ,greddy b controller, gsr cams................. what do you guys think ?? should i upgrade mani and wastegate or no ?
Old Mar 1, 2004 | 10:33 AM
JusT a Cx's Avatar
o yea i have a jdm 2 gen b16a (sir 2) and this is gonna be in a 5th gen hatch
Old Mar 1, 2004 | 10:34 AM
tygsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JusT a Cx &raquo;</TD></TR><TR><TD CLASS="quote">i plan on making 300whp with my set up @ 10psi of boost........ i jus heard the deltawastegate is garbage and that the drag manifold cracks .. soo iam looking into another one...... iam in the process of turbo'n now.... my set up consist of drag gen 3 turbo and wastegate.....spark racing intercooler, rc 440 injectors,hondata s100b,msd6aL ignition with blaster,arp headstuds,1mm headgasket(copper) ,greddy b controller, gsr cams................. what do you guys think ?? should i upgrade mani and wastegate or no ? </TD></TR></TABLE>
Definetly the wastegate, but save your money and dont upgrade the manifold..I had the drag manifold on my car for over a year and its was still in mint condition..GO with a tial 35mm and youll be set!
Old Mar 1, 2004 | 10:38 AM
JusT a Cx's Avatar
Default Re: (tygsr)
alright sweet.... what bar though cause i have no idea on how you dtermine which one to get...(iam new with turbo'n n the terms).....do u think my 300whp goal is resonable with my set up ??
Old Mar 1, 2004 | 10:41 AM
revhigh96's Avatar
the old DRAG manifolds crack, they changed them a little so you shouldnt have problems with that. Also if your manifold does crack they will replace it for FREE!
Old Mar 1, 2004 | 10:50 AM
tygsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JusT a Cx &raquo;</TD></TR><TR><TD CLASS="quote">alright sweet.... what bar though cause i have no idea on how you dtermine which one to get...(iam new with turbo'n n the terms).....do u think my 300whp goal is resonable with my set up ??</TD></TR></TABLE>
well I am assuming you have a drag kit..300whp is a reasonable goal with the right tuning. do you have hondata? internals?
Old Mar 1, 2004 | 11:36 AM
JusT a Cx's Avatar
Default Re: (tygsr)
wrote down everytying the set up consist of
Old Mar 1, 2004 | 03:15 PM
tygsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JusT a Cx &raquo;</TD></TR><TR><TD CLASS="quote">wrote down everytying the set up consist of
sorry I didnt see that. As long as the car is tuned well you might be able to hit 300whp. I would recommend upgrading your internals but that costs$$$..
Old Mar 1, 2004 | 05:04 PM
JusT a Cx's Avatar
Default Re: (tygsr)
my car is gonna be tuned threw this guy in michigan who is suppose to be really good..... i plan on rebuilding bottom end next winter...
Old Mar 1, 2004 | 05:56 PM
JusT a Cx's Avatar
bumpity bump
Old Mar 1, 2004 | 05:57 PM
Cramerox's Avatar
you never mentioned what turbo you are going to run? Its going to be harder to meet that 300hp goal with a small turbo.
Old Mar 1, 2004 | 06:05 PM
JusT a Cx's Avatar
Default Re: (Cramerox)
its the drag gen 3 t3/t4
Old Mar 1, 2004 | 06:09 PM
Cramerox's Avatar
well ive seen guys push 300whp with that manifold. If you want to stick with that mani upgrade to a tial wg. but the mentioned manifold above are great. With your setup you should be able to hit 300 depending on what octane you run.
Old Mar 1, 2004 | 06:33 PM
JusT a Cx's Avatar
upgrading the wastegate it is!!!!!!!!!!!!!!!!!! but soo many were mentiond........dunno which one
Old Mar 1, 2004 | 08:52 PM
revhigh96's Avatar
your best bet is probably the tial 38mm I think it is the largest that fits without any problems
